Speedings
This kind of report shows speed limitation violations. The speed limit depends on the method for determining the speeding selected in the properties of the unit on the Advanced tab.
The information which can be presented in this kind of report is described below.
ColumnDescription
BeginningThe date and time when the speed limit was exceeded.
LocationThe location of the device at the moment of speeding.
DurationThe time interval during which the unit was moving with an excessive speed. If the speeding was determined by one message, in the line 00:00 is written. In order for the speeding to be determined also by one message, it is necessary to indicate 0 as the minimum speeding time in the advanced properties of the unit.
Total timeThe time from the beginning of the first speeding to the end of the last speeding.
Max speedThe maximum speed within the period of speeding.
Speed limitThe maximum allowed speed on a particular road section or in the unit properties.
MileageThe distance travelled with the exceeded speed.
Avg speedThe average speed within the interval.
CountThe number of speed violations.
Interval filtering (by speeding duration, geofences/units) can be applied to this table.
You can use special markers for this report.
Other means to control speed are described in the notifications.
