Stops
A stop is one or more consecutive messages with a zero speed. Stops can be registered at lights, intersections, in traffic jams, etc.
Parameters to detect trips, parkings, and stops are adjusted in the trip detector. If there are several messages in succession, they are united in one stop. If the total time of such a stop reaches Minimum parking time, it is registered as a parking (not as a stop).
The information which can be presented in this kind of report is described below.
ColumnDescription
BeginningThe time when the stop started.
EndThe time when the stop ended.
DurationThe total time of the stop.
Total timeThe time from the beginning of the first stop to the end of the last stop.
Off-timeThe time from the end of the previous stop to the beginning of the current one (to be defined beginning from the second stop).
LocationThe address where the unit stopped.
CountThe number of stops.
See data in reports to learn how time (duration) can be formatted.
Interval filtering (by stop duration, geofences/units) can be applied to this table.
This kind of report can be supplemented with the corresponding markers on the map.
Stops should be distinguished from parkings.
