Fleetrun
Hecterra
NimBus
Other apps
Wialon for Android/iOS
Logistics
Wialon Local
Wialon Hosting
WiaTag
Configurator
LeaseControl
en
Contents
Unit Access Rights
  • access_rights
  • units
Access rights to a unit allow the user to see the location of this unit on the map, track its indicators (speed, altitude, sensor values, and so on), send commands and messages to it, use the unit in reports, notifications, jobs, and perform other actions with it.
You can change access rights to a unit in two ways: in the properties of this unit or in the user properties. In the user properties, you should select Units in the filter, mark the required unit in the list and select the rights the user should have to this unit. Read more about granting access rights here.
As in the case of other macro-objects, the rights to units are divided into standard and special ones.
Standard access rights
Below are the standard access rights the users may have to units.
Access rightDescription
View object and its basic properties
Allows seeing the unit on different lists and tabs, tracking its movement on the map in real time, and, if route access rights are granted, allows tracking the unit movement along the route.
If this access right is granted, the following data is displayed in the unit tooltip and extended information:
  • last message time;
  • location;
  • speed;
  • altitude;
  • number of visible satellites;
  • counter, parameter and sensor values;
  • geofences within which the unit is located;
  • assigned driver;
  • assigned trailer.
This access right also allows seeing the following information in the unit properties:
  • Unit name, creator, account, counters on the General tab. The names of the creator and account are shown if the View object and its basic properties right to them is granted.
  • Unit caption colour, Track colour and Usage of sensor colours sections on the Advanced tab.
  • Unit sensors on the Sensors tab.
  • Groups to which the unit belongs on the Unit groups tab (if unit group access rights are granted as well).
The View object and its basic properties access right doesn’t allow editing the unit properties and performing other actions with it. Additional access rights are required for this purpose.
The View object and its basic properties access right is given by default when any other unit access right is granted. To take this right away, you should deprive the user of all the access rights to the unit.
View detailed object properties
Allows seeing the following unit properties:
  • Parameters used in reports and message filtration parameters on the Advanced tab;
  • Eco driving tab;
  • Trip detector tab.
Manage access to this object
Allows seeing the Access tab in the properties of the unit and giving rights to it to other users, including by means of jobs and notifications.
Delete object
Allows deleting the unit from the system.
Rename object
Allows editing the unit name.
View custom fields
Allows seeing general custom fields (that is, the ones not marked as administrative) and the Profile tab in the unit properties.
Manage custom fields
Allows creating, deleting, changing general custom fields and editing the content of the Profile tab in the unit properties. This access right works only in combination with the previous one.
View admin fields
Allows seeing the custom fields marked as administrative ones in the unit properties.
Manage admin fields
Allows creating, deleting, editing custom fields marked as administrative in the unit properties. This access right works only in combination with the previous one.
Edit not mentioned properties
Allows editing the Unit caption colour, Track colour, and Usage of sensor colours sections on the Advanced tab.
Change icon
Enables the Icon tab in the unit properties, where you can select the unit icon and specify whether it should rotate depending on the direction of movement.
Request reports and messages
This access right allows:
  • getting unit tracks;
  • requesting unit messages;
  • running reports on the unit, including by means of notifications and jobs.
To request messages of the Log type and run a tabular report of the same name, the Manage object log access right is required, and to run the Custom fields report, the View custom fields and/or View admin fields rights are required.
Edit ACL-propagated objects
Doesn’t influence the user’s access to the unit.
Manage object log
In combination with the Request reports and messages access right, allows requesting messages of the Log type and running a report of the same name. To delete messages of the Log type, the Delete messages right is also required.
In combination with the Manage events right, allows adding custom records to the unit log by registering events.
View and download files
Allows using a file server to view and download files for the unit.
Upload and delete files
Allows using a file server to upload and delete files for the unit.
Special access rights
Below are the special access rights the users may have to units.
View connectivity settings
Allows seeing the following unit properties on the General tab:
  • device type;
  • server address;
  • unique ID;
  • phone number;
  • password of access to the unit.
If this access right is granted, the unit tooltip and extended information also display the device type, unique ID, and phone number.
Edit connectivity settings
Allows editing the following unit properties:
  • device type, unique ID, phone numbers, password of access to the unit on the General tab;
  • Parameters of message validity filtration on the Advanced tab (if the View detailed object properties right is granted).
In addition, if this right is granted to the user in whose properties the Can send SMS option is enabled, they can send SMS messages to the unit.
Create, edit, and delete sensors
Allow creating, editing and deleting sensors in the unit properties.
Edit counters
Allows performing the following actions with counters on the General tab:
  • changing the calculation method for the counters of mileage and engine hours;
  • resetting the GPRS traffic counter and saving its value in the unit history;
  • editing counter values.
In combination with the Use unit in jobs, notifications, routes, retranslators right as well as the Create, edit, and delete jobs and Create, edit, and delete notifications access rights to the resource, allows changing and saving counter values by means of jobs and notifications.
Delete messages
This access right works only with the Request reports and messages right and allows deleting the following types of messages:
  • data messages;
  • sent commands;
  • log (if the Manage log access right is granted).
Send commands
Allows sending commands to the unit in the following ways:
  • manually from the Monitoring tab;
  • Automatically by means of the Send a command to units job (if the Create, edit, and delete jobs access right to the resource and the Use unit in jobs, notifications, routes, retranslators right are granted);
  • automatically by means of a notification with the Send command action (if the Create, edit, and delete notifications access right to the resource and the Use unit in jobs, notifications, routes, retranslators right are granted);
  • manually from the application for iOS and Android.
Manage events
Allows registering the following types of events for the unit on the Monitoring tab:
  • record in the unit log (if the Manage log access right is granted);
  • custom event;
  • unit status;
  • fuel filling;
  • maintenance work.
In combination with the Use unit in jobs, notifications, routes, retranslators right as well as the Create, edit, and delete jobs and Create, edit, and delete notifications access rights to the resource, allows configuring notifications with the Register event for unit action.
In combination with the Register reports and messages access right, allows deleting messages of the Registered events type.
View service intervals
Allows seeing the Service intervals tab in the unit properties and data on the vehicle maintenance in the unit tooltip and extended information.
Create, edit, and delete service intervals
Allows creating, editing, deleting service intervals in the unit properties. This access right works only in combination with the previous one.
Import messages
Allows importing messages to the unit. Works only in combination with the Request reports and messages access right.
Export messages
Allows exporting messages from the unit to a file. Works only in combination with the Request reports and messages access right.
View commands
Allows seeing the Commands tab in the properties of the unit and exporting its commands.
Create, edit, and delete commands
Allows creating, editing and deleting commands in the unit properties. This access right works only in combination with the previous one.
Edit trip detector
Works only in combination with the View detailed object properties right and allows editing the following unit properties:
  • Parameters used in reports, Speeding, Driver activity sections on the Advanced tab;
  • Eco driving tab;
Allows performing the following actions:
  • creating jobs for the unit (if the Create, edit, and delete jobs right to the resource is granted);
  • configuring notifications for the unit (if the Create, edit, and delete notifications right to the resource is granted);
  • creating rides for the unit and configuring its automatic assignment to the rides (if route access rights are granted);
  • using the unit in retranslators.
Thank you for your feedback!
Text with the mistake Comment
Maximum 500 characters
