Hardware changelog
This changelog highlights new retranslator and device integrations, updates, and bug fixes.
July 21 – July 25, 2025
Integrations
Manufacturer Device/Retranslator Updates
WanWayTech AFAQY A1 Integrated the AFAQY A1 device.
Changes and improvements
Assistant Telematics AVT20 Added the TCF message decoding.
Queclink Wireless Solutions Queclink GV57MG, Queclink GL601CEU
  • Added decoding of GTBIE packet.
  • Improved parsing of GTBID packet.
Multi Portal RST-TG100 Added support for Envio Mensagem via transparent channel. To get data from the accessory, enable the Envio Mensagem by transparent option in the device configuration in the unit properties (wrench icon icon).
ST SUNLAB (Suntech) Suntech ST8395 Added support for Vidra Journey Keyboard and Vidra Temperature BLE Sensor via transparent channel. To get data from accessories, enable the corresponding options in the device configuration in the unit properties (wrench icon icon).
New parameters added:
  • vidra_keyboard_status
  • vidra_macro
  • vidra_driver_id
  • vidra_[sensor_ID]_temp
Shenzhen HHD Technology GPS Padlock G-300 (New Protocol)
  • Added new universal_sms_cmd SMS command.
  • Added the seal/unseal command via TCP channel.
  • Improved decoding of battery and keypad_passwd parameters.
July 14 – July 18, 2025
Integrations
Meitrack Meitrack MD833H Integrated the MD833H device.
Howen Technologies Howen Body Worn Camera Integrated the Howen Body Worn Camera device.
Queclink Wireless Solutions Queclink WR201LG Integrated the Queclink WR201LG device.
KRONH, S.A. KRONH Integrated the KRONH retranslator.
Skyangel MABE Integrated MABE retranslator.
PCL PCL ADAS_DMS dashcam Added RFID packet parsing into the following parameters:
  • rfid_card
  • rfid_effective_id
  • serial_number
Teltonika Teltonika FMC650 Improved DDD downloading algorithm.
SHENZHEN ZHENCB TECHNOLOGY CO., LTD. ZHENCB J16 Added new accessory data decoding into the following parameters:
  • measurement_unit
  • alcoholicity
  • test_mode
Oigo Telematics MG Series Added the block_engine and unblock_engine commands.
ATrack ATrack AW500 Added FTP video files uploading support.
eTrans Solutions DARSH_Lite Added the freeform_msg message command support.
Queclink Wireless Solutions Queclink GL52L
  • Added parsing of LoRaWAN data (info, location).
  • Debugged using msg_tests.
  • Added tests.
Babelstar CMSV6 Gateway Added parsing of LoRaWAN data.
Suntech Suntech ST340, Suntech ST310U Added msr command type for Suntech devices.
AutoDefend TTC-CV-P112 Added 0x67 video alarm names.
Assistant Telematics AVT20 Improved the ble_custom parameter decoding.
Queclink Wireless Solutions Queclink GV300CAN Added the ability to select the speed source.
Jimi IoT (Concox) JM-LL303 Added 0x23 packet skipping function. To skip heartbeat (0x23) packet registration, enable the Do not register Heartbeat packet (0x23) option in the device configuration in the unit properties (wrench icon icon).
July 7 – July 11, 2025
Integrations
Manufacturer Device Updates
BSJ Technology BSJ Video Integrated the BSJ Video video.
Jimi IoT (Concox) JC182 Integrated the device JC182.
AOVX AOVX V-Series Added the uart_msg_text parameter.
Asiatelco Technologies AS31 Added new parameters decoding:
battery_percentage, battery_voltage, engine_hours, battery_in_use, num_batteries, battery_voltage_NUM.
Teltonika Teltonika FMC225 Added video functionality.
Queclink Wireless Solutions Queclink CV200XEU/XNA Improved FTP video uploading.
Queclink Wireless Solutions Queclink GV58CEU Added support for Extended GTCAN Parameters. To get data from CAN, enable the Extended GTCAN Parameters option in the device configuration in the unit properties (wrench icon icon).
ST SUNLAB (Suntech) Suntech ST4500 Added:
  • UBL(ASCII) report parsing,
  • Vidra BLE concrete mixer support.
Ruptela Ruptela Pro5 Lite Supported ID 171 and 172 parsing in HEX.
Jimi IoT (Concox) VL802 Added 0x38 packet decoding for VL802. New parameters:
mileage_statistic, drivers_license_length, license_information, buzzer_alarm_identifier.
Gosuncn All devices Improved the decoding algorithm.
Assistant Telematics AVT110 Added the DDD saving functionality.
AutoDefend TTC-CV-P112 Improved the filename saving.
T-Zone TT18-4G Improved the device commands.
Queclink Wireless Solutions Queclink GV500CG Improved the +RESP:GTATI packet type decoding.
Xexun Xexun DDX04 Improved the device_status parameter decoding.
June 30 – July 4, 2025
Integrations
AESSAT AESSAT Added the AESSAT retranslator.
Bolide Technology Group MVR9308-4GW Integrated the device MVR9308-4GW.
TYT Electronics Co., Ltd. IP668 Improved the timestamp decoding.
Shenzhen Coban Electronics Coban GPS303-C Added the SMS channel for commands.
Meitrack Meitrack MDVR MD500S Added new commands to prevent editing the parameters list in common output_off and output_on.
Jimi IoT (Concox) JC261 Added the following events: Door Open, Door Close, Facial Recognition (AFIS), Facial Recognition (AFIF), Seatbelt (AWSB), Seatbelt (ANWSB).
Teltonika Teltonika FMC650 Unified codec12 commands format.
June 23 – June 27, 2025
Streamax Technology Streamax AD PLUS 2.0 Improved the GETSUPPORTSERVICE message decoding.
AOVX AOVX V-Series Added the new Data type parameter for the Downlink Transparent Transmission command.
Teltonika Teltonika FMC650 Fixed output commands.
June 16 – June 20, 2025
Integrations
MOKO MKGW3 Integrated the Gateway support.
Queclink Wireless Solutions Queclink GV58LAU Added the hour_meter_count parameter decoding.
Teltonika Teltonika FMB125 Added the DG400 messages decoding into the following parameters: dg400_total_weight, dg400_partial_weight, dg400_measure.
Teltonika Teltonika FMC225 Added new command forward_to_rs232.
Suntech Suntech ST4305 Improved the decoding algorithm.
Queclink Wireless Solutions Queclink GV55S Improved the HEX protocol decoding.
eTrans Solutions DARSH_Lite Added custom_msg_darshlite command.
AOVX AOVX V-Series Improved the custom_msg command sending.
Shenzhen Cantrack Technology Co., Ltd Cantrack G900LM Improved the decoding algorithm.
ST SUNLAB (Suntech) Suntech ST8300 Added support for Vidra Betoneira via transparent channel. To get data from Vidra Betoneira, enable the Vidra Betoneira by transp option in the device configuration in the unit properties (wrench icon icon).
June 9 – June 13, 2025
Galileosky Galileosky 7x Added the new tags decoding into the following parameters: wifi_modem_status, wifi_error_code, gsm_modem_status, network_reg_status, gprs_status, free_ram, archive_total_packets, archive_sent_main, archive_sent_additional, archive_last_record, wifi_mac, ble_mac, last_reset_time, reset_reason, reset_reason_count, signal_to_noise_ratio_avg, sd_status, sd_errors, collector_total_packets, collector_sent_main, collector_reserved, client1_mac, client2_mac, client3_mac. See parameter description.
ERM Advanced Telematics StarLink Tracker Added support for EMIX via transparent channel. To get data from EMIX enable the Activate to receive data from EMIX option in the device configuration in the unit properties (wrench icon icon).
AOVX AOVX V-Series
  • Added the Downlink Transparent Transmission command .
  • Added support for SGBras keyboard via transparent channel. To get data from SGBras keyboard, enable the Use SGBras keyboard option in the device configuration in the unit properties (wrench icon icon).
BoShiJie Technology BSJ Smart Watch S Series Added the command SET_LOCATION_MODE.
Howen Technologies Howen VSS Improved the connection with Howen VSS.
TOPFLYTECH Co., Limited KnightX 100 Added WiFi positioning support.
Assistant Telematics AVT110 Added +DFI packet decoding into the following parameters: protocol_ver, last_pack_flag, firmware_ver, hardware_ver, network_type, csq_rssi, gnss_state, gnss_hdop, speed, gnss_corner, lat, lon, gnss_tm, gps_sv_n, beidou_sv_n, galileo_sv_n, can_hw_ver, can_sw_ver, can_sn, can_sync_model_id, can_module_car_name, can_module_sync_st, tacho_support, tacho_can1_st, tacho_can2_st, tacho_check_info, tacho_info, tco_driver1_id, tco_driver2_id, tacho_driver1_name, tacho_driver2_name, vin, range, fuel_lvl_l, fuel_lvl_p, total_fuel, engine_rpm, engine_cool_temp. See parameter description.
SHENZHEN ZHENCB TECHNOLOGY CO.,LTD ZHENCB J16 Improved the block/unblock_engine command.
ORBCOMM ORBCOMM Transportation Platform Improved the coordinates decoding.
TOPFLYTECH Co., Limited CyberlabelX 100 Added the new parameters decoding: ext_temp, ext_hum, device_int_temp_high_prec. See parameter description.
Ruptela Ruptela Pro5 Lite Improved the can_veh_id parameter registration.
Verizon Connect Inoslv V8 Improved the messages decoding algorithm.
T-Zone TT19 Improved the command sending algorithm.
eTrans Solutions DARSH_Lite Improved the inputs/outputs decoding.
TOPFLYTECH Co., Limited Topflytech SolarGuardX 100 Added the sub-lock information decoding: fw_vers_ext, alarm_index, lock_status, dev_status, pwr_int, solar_voltage, temp, mac_address, device_id. See parameter description.
Geotab GEOTAB GO9 Added the following parameters decoding: ign, cranking_volt, device_volt, battery_volt, battery_lvl, engine_road_speed, engine_speed, engine_oil_temp, engine_coolant_temp, raw_engine_hours, engine_hours, device_total_fuel_used, device_total_idle_fuel_used, total_fuel_used, fuel_lvl, adblue_def_tank_lvl, tell_tale_adblue_lvl, tell_tale_adblue_tampering.
June 2 – June 6, 2025
Gosafe Gosafe G16S
  • Improved the tacho parameters validation.
  • Improved the can_fuel_lvl_p parameter decoding.
SEEWORLD Technology Corporation Seeworld S21L Added the send_txt_command command.
ST SUNLAB (Suntech) Suntech ST300H Added commands for SW101, the command response will be registered in sw101_msg parameter.
Tramigo Tramigo TF150 Improved the coordinates decoding algorithm.
Jimi IoT (Concox) VL103 Added the BLE data decoding.
Queclink Wireless Solutions Queclink CV200XEU/XNA Improved the GTCAN messages decoding for the ASCII protocol type.
Queclink Wireless Solutions GV50CG Improved the decoding algorithm.
Galileosky Galileosky 7x Added new tags 0x11 (parameter archive_num) and 0x36 (parameter pdop).
Assistant Telematics ATL100 Changed the message time from GNSS to registered.
Teltonika Teltonika FMM650 Removed the upper limit from setparam and getparam commands.
iStartek iStartek VT300-L, iStartek PT60-L, iStartek VT100L, iStartek VT200L Improved the decoding of the device command answers.
May 26 – May 30, 2025
Integrations
GEOTAB GEOTAB GO9 Updates, fixes, and refactoring:
  • Enhanced GPS and DTC data retrieval.
  • Expanded mapping capabilities between Geotab and Wialon.
  • Refined error and warning messages.
    Assistant Telematics AVT110 Improved the CAN bus data decoding.
    Assistant Telematics AVT20 Added +SCF report decoding into the following parameters:
    asc_status, asc_x_forward, asc_y_forward, asc_z_forward, asc_x_horizon, asc_y_horizon, asc_z_horizon, asc_x_gravity, asc_y_gravity, asc_z_gravity, asc_stable_num, asc_x_stable, asc_y_stable, asc_z_stable
    Ruptela Ruptela Pro5 Lite Added support for TPMS at CAN custom IOs via transparent channel. To get data from TPMS, enable the TPMS at CAN custom IOs option in the device configuration in the unit properties (wrench icon icon).
    Gosuncn Gosuncn GD201 Added the AGPS message decoding.
    Streamax Technology Streamax X3-H0402 Added parsing of UPLOADDRIVERINFO packet into avl_driver parameter.
    May 19 – May 23, 2025
    Integrations
    SelectCam AI SelectCam DC10, SelectCam DC20, SelectCam M8 Integrated the new SelectCam AI devices.
    BSJ Technology HW-D03G, HW-C02G, EG01G, BSJ Video, A5C-8 Added the 0x00E2 packet decoding into adc0 and adc1 parameters.
    X3TECH All devices Added the base station positioning protocol (0x24) decoding.
    Assistant Telematics AVT110 Added BLE messages parsing for AVT110.
    Queclink Wireless Solutions Queclink GV56 Added the Technoton DFM S7 parameters decoding.
    Queclink Wireless Solutions Queclink CV200XEU/XNA Added bt_raw_data parameter.
    Jimi IoT (Concox) JC181 Fixed the alm_evt_tm parameter decoding.
    Teltonika Teltonika FMC225 Added support for Chafon CF561-R via transparent channel. To get data from Chafon CF561-R, enable the Parse UFH TAG from Chafon CF561-R option in the device configuration in the unit properties (wrench icon icon).
    TechnoKom Avtograph Added driver_msg command.
    Ruptela Ruptela Pro5 Lite Improved the decoding algorithm for the SGBras messages.
    Lynkworld Lynkworld LW2G-4A Added block_engine/unblock_engine commands.
    Suntech Suntech ST340UR, Suntech ST300P, Suntech ST340, Suntech ST300F, Suntech ST300R, Suntech ST300H, Suntech ST300 Added support for SW101 via transparent channel. To get data from SW101, enable the SW101 accessory connected option in the device configuration in the unit properties (wrench icon icon).
    Teltonika FMC/FMM130, FMC/FMM001, FMC/FMM003, FMC/FMM880, FMC/FMM640, FMC/FMM650 Added set_odometer command for Teltonika devices.
    May 12 – May 16, 2025
    Integrations
    WanWayTech WanWay GS300 Integrated the new device WanWay GS300.
    Great-Will GAT24 Integrated the new device GAT24.
    Hikvision HikVision gateway Added the reboot command.
    Hikvision Hikvision AE-DI2032-G40, Hikvision AE-DI5042-G4 Added the set_device_parameters, block_engine, unblock_engine commands.
    Huiye IoT Technology HYN100 Improved the ACK sending for the device.
    Queclink Wireless Solutions Queclink GV300W Added the motion_status_hex parameter.
    Queclink Wireless Solutions Queclink CV200XEU/XNA Improved FTP file loading.
    WanWay Tech WanWay GS900, WanWay GS10G Added the acc_status parameter registration.
    Tramigo Tramigo T24 Added the trip message decoding into the following parameters: start_bearing_to_tld, start_distance_to_tld, end_bearing_to_tld, end_distance_to_tld, trip_distance, avg_speed, max_speed, idle_time. See parameter description.
    Xirgo Technologies - BCE BCE FM Tacho protocol Improved the DDD file saving algorithm.
    Teltonika Teltonika FMC650 Improved the io_10494 and io_10496 parameter decoding.
    Teltonika Teltonika FMB640 Fixed stationary coordinates option.
    Shenzhen Cantrack Technology Co., Ltd Cantrack G06L Added Cantrack G06L heartbeat packet with a battery parameter decoding.
    Bitrek BI 910 TREK Added the hdop parameter decoding.
    Avema AT35 RTK Added parsing of AT35RTK data: pwr_int, gnss_fix, gnss_rms_value, text_msg. See parameter description.
    Akroz VIRLOC VL08 Improved the driver_id parameter registration.
    Suntech Suntech ST8300 Added support for SW101 via transparent channel. To get data from SW101, enable the SW101 accessory connected option in the device configuration in the unit properties (wrench icon icon).
    Multi Portal RST-TG100 Added support for using position info from LBS via transparent channel. To get data from LBS, enable the Use position info from LBS option in the device configuration in the unit properties (wrench icon icon).
    Jointech Jointech JT705C Improved the decoding algorithm.
    May 5 – May 9, 2025
    Integrations
    Jointech Jointech JT705C Integrated the new device Jointech JT705C.
    Tzone Digital Technology TT18-4G Integrated the new device TT18-4G.
    TOPFLYTECH Co., Limited Topflytech TLD2-D Added the OBD parameters decoding for the 4103 content type.
    Ruptela Ruptela Asset5 Improved the LBS positioning parameters decoding.
    Wireless Links Piccolo ST Added the tag_nearest_id and tag_nearest_rssi parameters.
    AOVX AOVX V-Series Added support for BlueCircuites TDI CANBUS decoder via transparent channel. To get data from TDI, enable the Use TDI Telemetria by transparent option in the device configuration in the unit properties (wrench icon icon).
    T-Zone TT19 Added the custom_msg command.
    WanWayTech WanWay GS10G Added Digital Inputs (0x1F) decoding into the din1 and din2 parameters.
    Jimi IoT (Concox) VL106 Improved commands for engine blocking and unblocking.
    April 28 – May 2, 2025
    Integrations
    BS Technotronics BSTPL 17IS GLT Integrated the new device BSTPL 17IS GLT.
    Tor.ai Pluto 312 Integrated the new device Pluto 312.
    Queclink Wireless Solutions Queclink GV350M Improved the decoding algorithm for the GTERI.
    WanWay Tech WanWay GS12 Added the acc_status parameter registration.
    April 21 – April 25, 2025
    Integrations
    BSJ Technology BSJ Smart Watch S Series Integrated the BSJ Smart Watch S Series.
    ORBCOMM ORBCOMM Transportation Platform Integrated the ORBCOMM Transportation Platform.
    AutoDefend TTC-CV-P112, TTC-CV-P360, TTC-CV-P450 Integrated the AutoDefend video devices.
    DAHUA TECHNOLOGY Dahua DAE-CDR8213-GFW, MXVR4104-GFWI Integrated the Dahua devices.
    Assistant Telematics AVT20 Added parsing of BLE data with the following parameters:
    • ble_num
    • ble_mac
    • ble_rssi
    • ble_batt_volt
    • ble_temp
    • ble_hum
    • ble_door_st
    • ble_lum
    • ble_fuel
    • ble_fuel_fr
    • ble_custom1
    • ble_custom2
    • ble_custom3
    • ble_custom4
    • ble_custom5
    • ble_custom6
    Rinho Telematics All devices Added ACK for messages with zero timestamp.
    Control T Control T Improved the algorithm for the Control T retranslator.
    Queclink Wireless Solutions Queclink GV355CEU Added the bt_nearest_mac2 and bt_nearest_rssi2 parameters.
    Improved the adc1, adc2, adc3 parameters decoding.
    Queclink Wireless Solutions Queclink GV350M Added GTTPM message parser with parameters:
    • mcc
    • mnc
    • lac
    • cell_id
    • report_type
    • mileage
    • tire_position_N
    • tire_bat_volt_N
    • tire_press_N
    • tire_temp_N
    • tire_status_N
    See paramater description.
    iTER Iter 155 Added support for RFID reader via transparent channel. To get data from RFID reader, enable the RFID reader by RS232 option in the device configuration in the unit properties (wrench icon icon).
    Vanguard IoT Vanguard VA20 Added the 0x51, 54, 58, E1, E2, E3 information IDs decoding with parameters:
    • temp_N
    • wifi_mac_N
    • wifi_rssi_N
    • hum_N
    • version_number
    • battery
    • pwr_ext
    • iccid
    • temp
    • hum
    • temp_hum_stat
    • state
    Huiye IoT Technology HYN100, HYN600 Improved the decoding algorithm for the devices.
    Howen Technologies Hero-ME40-02 Added the Storage abnormal alarm (alarm_ec=16) decoding into the num and st parameter.
    Naturelink Naturelink NL01, Naturelink NL02 Added the Eurosens FLS and Eurosens DDS sensor data decoding with parameters:
    • eurosens_fls_idN
    • eurosens_fls_rssiN
    • eurosens_fls_statusN
    • eurosens_fls_detector_valueN
    • eurosens_fls_detector_fuel_volumeN
    • eurosens_fls_detector_fuel_percentN
    • eurosens_fls_tempN
    • eurosens_fls_batteryN
    • eurosens_dds_idN
    • eurosens_dds_rssiN
    • eurosens_dds_statusN
    • eurosens_dds_angleN
    • eurosens_dds_weightN
    • eurosens_dds_axle_loadN
    • eurosens_dds_parameter_numberN
    • eurosens_dds_parameterN
    • eurosens_dds_tempN
    • eurosens_dds_batteryN
    April 14 – April 18, 2025
    Meitrack Meitrack MD522S Fixed negative altitude parsing.
    iStartek iStartek VT200L Added parsing of event 53 (RFID) into a rfid_card_id parameter.
    TOPFLYTECH Co., Limited Topflytech TorchX 100 Added support for Escort DU Sensor via transparent channel. To get data from Escort DU Sensor enable the Use Escort DU Sensor option in the device configuration in the unit properties (wrench icon icon).
    TOPFLYTECH Co., Limited SolarX 120 Added parsing of Alarm Message with LBS (From Server) (0x270x270x64).
    TOPFLYTECH Co., Limited HeroX 100 Added VIN parameter validation.
    Jimi IoT (Concox) JC400 Improved the curr_volt parameter registration.
    T-Zone TT19 Added the TT19SI and TT19SE sensor data decoding.
    Toptraking Toptraking G50L Added parsing of 0x1B packet.
    MiCODUS MV710G Added engine block/unblock command.
    Vanguard IoT Vanguard VA12 Changed name from Vanguard Asset Tracker to Vanguard VA12.
    WanWayTech WanWay GS10G Added the RFID decoding from the 0x94 message type into avl_driver parameter.
    Gosuncn All products Added support for the v4.0.0 protocol version with the following parameters:
    • odometer_unit
    • soc
    • soh
    • bat_pack_cur
    • bat_pack_volt
    • bat_pack_charge_state
    • remain_dist
    • bat_pack_temperature
    • dist_til_servese
    • engine_runtime
    • fuel_type
    April 7 – April 11, 2025
    Queclink Wireless Solutions Queclink GV350CEU Added the GTDTT message type decoding into the dtt_data parameter.
    Toplovo TL-900 Added the Time zone correction property. For the correct message time registration fill in the device timezone in a Timezone field in the device configuration in the unit properties (wrench icon icon).
    BS Technotronics BSTPL 17IS BYD Changed the parameters format from int to hex for the following parameters:
    • veh_speed
    • pwr_soc
    • mileage
    • pwr_int_discharge
    • pwr_int_charging
    • bat_temp1
    • bat_temp2
    • bat_temp3
    • bat_temp4
    • state_of_health
    • motor_temp
    • time_to_full_charge
    T-Zone TT19 Added decoding into the following parameters:
    • machine_status
    • battery
    • command_type
    • command_len
    • command_info
    • downward_command_type
    • downward_command
    • downward_result
    • downward_command_info
    March 31 – April 4, 2025
    Integrations
    Transight Discovery Series Integrated the Discovery Series device.
    Queclink Wireless Solutions Queclink GV50CEU Added support for the HEX message type.
    Streamax Technology All devices Improved the data registration functionality.
    Streamax Technology Streamax AD PLUS 2.0 Improved the video receiving functionality by adding the playback stop function.
    Jointech Jointech JT701D Fixed timestamp decoding.
    Control T Control T Changed the property name for the Control T retranslator.
    Teltonika Teltonika FMM13A, Teltonika FMM230, Teltonika FMM00A Added an option to disable registration of command responses via transparent channel. To use this feature, enable the Do not register response to command option in the device configuration in the unit properties (wrench icon icon).
    Cradlepoint Cradlepoint IBR900 Fixed a parsing error.
    Howen Technologies All devices Removed the Timezone property from unit properties. Timezone is now set automatically from the device configuration, including daylight saving time.
    flespi Ruptela HCV5 Lite (flespi) Improved parameter registration:
    • tco_drv_comp_bef_lst_wk_dur_1
    • tco_drv_comp_sec_bef_lst_wk_dur_1
    • tco_drv_rem_10_hr_drv_tms_1
    • tco_drv_rem_rdc_dly_rst_prds_1
    • tco_drv_rem_wkly_drv_dur_1
    • tco_drv_unkwn_prds_prsnt_stat_1
    • tco_drv_wkly_rst_calc_stat_1
    • fms_tell_tale_wndscrn_wshr_fld_st
    Vanguard IoT Vanguard Standard Tracker Added the 0xE1 information ID in 0x0900 packet with the following parameters:
    • temp
    • hum
    • temp_hum_stat
    • state
    Teltonika Teltonika FMC125, Teltonika FMB130 Added support for LinkedCore CAN60 via transparent channel. To receive data from LinkedCore CAN60, enable the Use LinkedCore CAN60 option in the device configuration in the unit properties (wrench icon icon).
    March 24 - March 28, 2025
    Integrations
    BS Technotronics BSTPL 17IS Integrated the BSTPL 17IS device.
    Queclink Wireless Solutions Queclink GV56 Added the GTHBM and GTTOW packets decoding.
    Suntech Suntech ST4215 Improved command sending.
    Tramigo Tramigo T24/T25 Added the virtual channel for the commands.
    Teltonika Teltonika FMA110 Added coordinates for stationary units.
    Streamax Technology All devices Added parsing of GETSTORAGEINFO response.
    Assistant Telematics AVT110 Added the NMEA2000 mask field for AVT110.
    Ruptela Ruptela Eco5 Added the cmd_output_4th_gen command.
    March 17 - March 21, 2025
    MettaX Digital (Shenzhen) Co., Ltd MettaX MC904 Added support for driver alignment packet (0E10) with the following parameters:
    - comparsion_res
    - aligh_similar_threshold
    - aligh_similar
    - alagh_type
    - driver_id
    - picture_format
    Queclink Wireless Solutions Queclink GV57CG Added Hour Meter Count registration into the hour_meter_count Wialon parameter.
    Queclink Wireless Solutions Queclink GV55W Improved mileage decoding.
    Queclink Wireless Solutions Queclink GV350CEU Added support for ET-45 Expander via transparent channel. To receive data from ET-45 Expander, enable the ET-45 Expander by transp option in the device configuration in the unit properties (icon ).
    Jimi IoT (Concox) Concox JM-LL01 Added SMS response decoding.
    Jimi IoT (Concox) JM-LL303 Added temperature and humidity data with timestamp decoding (0x58 Information content in 0x94 packet type) with the following parameters:
    - temp
    - hum
    SEEWORLD Technology Corporation Seeworld R12L Improved voltage parameter decoding.
    Assistant Telematics AVT20 Added Satellites Number Mask decoding with the following parameters:
    - gps_sats_num
    - beidou_sats_num
    - galileo_sats_num
    - glonass_sats_num
    T-Zone TT19 Added virtual channel for commands.
    Streamax Technology All Streamax models Added response to text parameter.
    Vanguard IoT Vanguard Standard Tracker Improved battery value decoding.
    March 10 - March 14, 2025
    Integrations
    TYT Electronics Co., Ltd. IP668 Integrated the IP668 personal tracking device.
    Suntech Suntech ST8300 Enhanced the custom_msg command format with the following improvements:
    - Added # as a separator
    - Implemented automatic unique ID filling
    - Added responses for REQ
    Example command: PRG;10;00#1;01#testapn.test
    Queclink Wireless Solutions Queclink GV300W Added support for CAN60 via transparent channel. To receive data from CAN60, enable the Use CAN60 option in the device configuration in the unit properties (icon ).
    Teltonika Teltonika FMC650 Added support for AL100 via transparent channel. To receive data from AL100, enable the AL100 by transp option in the device configuration in the unit properties (icon ).
    March 3 - March 7, 2025
    Changes and Improvements
    Meitrack Meitrack MDVR MD500S Added adaptation for the A9C Timeline and the option to choose AB8 Timeline. To use the AB8 timeline decoding type, enable the Uses AB8 command to generate timeline instead of A9C option in the device configuration in the unit properties (icon ).
    TOPFLYTECH Co., Limited PioneerX 101 Added acknowledgment support for the Accident via Acceleration Message (0x7) message type.
    TOPFLYTECH Co., Limited Topflytech SolarGuardX 100 Added commands to Add/Delete NFC IDs in the unlock white list.
    Suntech Suntech ST8300 Improved command sending functionality .
    Lytx Surfsight AI-12 APIv2.0 Fixed video retrieval functionality for devices connected to EU servers.
    Queclink Wireless Solutions Queclink GV350CEU Added option to register command responses in the driver chat. To receive command responses, enable the Registration of command responses option in the device configuration in the unit properties (icon ).
    Streamax Technology Streamax AD PLUS 2.0 Added HD option for Streamax devices.
    Baita Tecnologia Baita MAC 4G Improved Stop Duration (type 21) packet decoding.
    T-Zone TT19 Added TCP custom_msg command.
    Sukarne Sukarne retranslator Added refrigerator_van as type 2 for improved vehicle classification.
    Queclink Wireless Solutions Queclink GB130MG Added Queclink Track Protocol decoding.
    February 24 - February 27, 2025
    Integrations
    Manufacturer Device/Protocol Updates
    ROOTCLOUD MachineLink API Integrated the MachineLink API for industrial equipment monitoring.
    Apache Apache thermograph Integrated the Apache thermograph for temperature monitoring solutions.
    Queclink Wireless Solutions Queclink Track Protocol Added OBD data decoding with the following parameters:
    total_veh_dist, total_fuel_used, total_fuel_used_high_res, total_hours_oper, vehicle_speed, engine_rpm, engine_torque, engine_fuel_rate, fuel_lvl, fuel_lvl_2_tank, engine_cool_temp, acc_pedal_pos, engine_load, clutch_switch, brake_switch, cruise_control, pto_gov_state, park_brake_switch, brake_pedal_pos, act_retard_perc_torque, dr_demand_retard_perc_torque, retard_select_non_eng, retard_torque_mode_st, at_least_one_pto_eng, steering_wheel_angle, ambient_air_temp, door_status, transmission_gear, air_inlet_pressure, axle_weight_1, axle_weight_2, axle_weight_3, axle_weight_4, service_dist, service_brake_air_press_cir_1, service_brake_air_press_cir_2, ad_blue_tank_lvl, fuel_type, tot_gas_fuel_used, alternator_st_1, alternator_st_2, alternator_st_3, alternator_st_4, abs_ebs_amb_warn_signal_st, telltale_st, high_engine_temp, vin, driver_1_card_st, driver_2_card_st, driver_1_time_rel_st, driver_2_time_rel_st, driver_1_work_st, driver_2_work_st, driver_seat_belt, oil_lvl, coolant_lvl, tract_mount_trailer_abs_warn, hv_av_charge_power, hv_av_discharge_power, hv_tot_energy_throughput, hv_battery_volt, hv_cell_volt_max, hv_cell_volt_max_num_st, hv_cell_volt_min, hv_cell_volt_min_num_st, range_dist, hv_total_charge_energy, soc, soh, hv_cell_minmax_mux_st, hv_cell_temp_max, hv_cell_temp_max_num_st, hv_cell_temp_min, hv_cell_temp_min_num_st, hv_battery_curr, hv_battery_temp, hv_charge_st, tire_press, oil_temp, v12_batt_volt, tire_loc.
    Jimi IoT (Concox) VL103, JM-VL03M Improved the block_engine and unblock_engine commands.
    MiCODUS MiCODUS MV930G, MiCODUS MV710G Added 0x8500 packet decoding for expanded device functionality.
    Queclink Wireless Solutions Queclink Track Protocol Fixed negative altitude value calculation.
    Shenzhen Coban Electronics Coban GPS303-C Improved block_engine and unblock_engine commands.
    Ruptela Ruptela Eco5 Lite Added new parameters:
    - beacon_nearest_id
    - beacon_nearest_rssi
    - io_8_760_hex
    - io_8_761_hex
    February 17 - February 21, 2025
    GLONASSsoft UMKa302 Added Wialon ecodriving parameters for driver behavior monitoring:
    - wln_accel_max
    - wln_brk_max
    - wln_crn_max
    Ruptela All Ruptela devices Added setcfg command.
    Shenzhen Cantrack Technology Co., Ltd Cantrack G05 Fixed speed calculation algorithm.
    Teltonika Teltonika FMB125 Added support for Digi-Star GT400 via transparent channel. To receive data from Digi-Star GT400, enable the Parse data from Digi-Star GT400 option in the device configuration in the unit properties (icon ).
    Assistant Telematics AVT110, AVT20, AVT50 Fixed total_mileage and mileage parameters registration.
    Lytx Surfsight AI-12 APIv2.0 Added query_photo command to request on-demand images from the device.
    GoTrack G400 Fixed location calculation.
    February 10 - February 14, 2025
    Integrations
    Xexun DDX04 Integrated the new DDX04 personal tracking device.
    eTrans Solutions DARSH_Lite Added the following parameters:
    packet_type, source_id, task_status, command_source, cmd_type, ot_string, sequence, firm_ver, packet_status, veh_num, net_oper, net_type, signal_pwr, main_pwr, pwr_int, ext_adc, dev_state, mileage, dyn_field_#, rfid, rfid_msg, key_val, key_msg, fuel_sensor_N, fuel_temp_$num, fuel_temp_Nmsg, uhf_card, cell_id, lac, mnc, mcc, tmpN, prev_speed, cur_speed, alert_calc
    Jointech Jointech JT709A Added SMS command sending channel.
    Assistant Telematics AVT110 Improved decoding of all_geo_status and driver_id parameters.
    Assistant Telematics AVT20 Improved decoding of the main_pwr_vcc parameter.
    Teltonika All Teltonika devices Renamed block/unblock engine commands to “CAN-CONTROL Block/Unblock engine”.
    Jimi IoT (Concox) JM-LL303 Improved BLE beacon parameters decoding.
    iStartek iStartek VT300-L, iStartek PT60-L, iStartek VT100L, iStartek VT200L Added new commands.
    Tramigo Tramigo T24 Improved command response decoding.
    SEEWORLD Technology Corporation Seeworld S5L Added support for weight sensor data decoding. To receive weight data, enable the Register weight data option in the device configuration in the unit properties (icon ).
    Added 0x30 packet decoding with the following parameters:
    - rfid_hex
    - rfid
    3 February - 7 February, 2025
    Integrations
    BWS IoT E3+4G Integrated the E3+4G device.
    Teltonika Teltonika FMC225 Added support for JT606X fuel level sensor via transparent channel. To get data from JT606X, enable the JT606X sensor by transp option in the device configuration in the unit properties (icon ).
    The following parameters appear in messages:
    - jt606x_fuel_id
    - jt606x_command_code
    - jt606x_remaining_fuel_perc
    - jt606x_fuel_level
    - jt606x_fuel_level_litres
    - jt606x_fixed
    Lytx Surfsight AI-12 APIv2.0 Added the possibility of choosing the EU region of service. To get data from EU server, enable the Use EU region of service option in the device configuration in the unit properties (icon ). US region of service will be used if disabled.
    Suntech Suntech ST4305 Added the l_asgn{i}_dec parameter that represents the decimal value of the l_asgn, where {i} index shows the number of the l_asgn parameter.
    Gosuncn Gosuncn GD201 Fixed the temp_{i} parameter registration.
    Baita Tecnologia Baita MAC 4G Added decoding for the following packet types: 17, 18, 23, 25, 26, 27, 28, 29, 48.
    Streamax Technology All Streamax devices Added the possibility to choose the livestream and playback quality.
    27 January - 31 January, 2025
    Integrations
    Jimi IoT (Concox) JC371 Integrated the JC371 Jimi IoT (Concox) device.
    Altotrack Altotrack Integrated the Altotrack retranslator.
    Atlanta Systems Pvt Ltd. L400 Added data decoding from multiple LLS sensors.
    WanWayTech WanWay GS10G Added Escort BLE FLS data parsing with the following parameters:
    - fuel_freq
    - fuel_temp
    - fuel_batt
    Teltonika Teltonika FMC225 Added support for secondary Unique ID.
    Howen Technologies All devices Removed _video commands from vrt commands.
    Assistant Telematics AVT110, AVT130 Improved the multi-package messages decoding functions.
    Howen Technologies Hero-MC30-01 Renamed the following parameters:
    - durtrip_dur
    - max_speedtrip_max_speed
    - avg_speedtrip_avg_speed
    Iridium Iridium Edge Solar Fixed the negative longitude values registration.
    Meitrack Meitrack T622G Added command for Iridium satellite periodic data upload interval.
    20 January - 24 January, 2025
    Integrations
    TOPFLYTECH Co., Limited CyberLabelX 100 Integrated the CyberLabelX 100 device.
    Sensata INSIGHTS (Xirgo Global) Xirgo FMS500 TACHO Fixed speed registration for the Use CAN speed (truck and bus) option in the device configuration in the unit properties (icon ).
    Sensata INSIGHTS (Xirgo Global) Xirgo XT-4600 Improved the decoding algorithm for Wialon Local.
    Howen Technologies Hero-ME41-04 Added registration for the following parameters:
    - modem_status
    - trigg_threshold
    - alc_concentr
    Ministry of Transport of the People’s Republic of China JT808 Improved the ACK (0x8103) command formation.
    Digital Matter Telematics Barra Edge Added cell tag decoding with the following parameters:
    - mcc
    - mnc
    - lac
    - cid
    - rsrq
    - rx_lvl
    - taN
    - srvN
    - nwN
    - earfcnN
    - pcidN
    - rsrqN
    - delta_tN
    Queclink Wireless Solutions Queclink GV355CEU Added decoding for the GTALM packet type into alm_N parameters. To use this functionality, enable the Parse GTALM parameters option in the device configuration in the unit properties (icon ).
    Navtelecom Navtelecom SMART S-24xx Improved the decoding algorithm.
    13 January - 17 January, 2025
    Integrations
    Widetech WEB LOCATION REPORTER Integrated the Web Location Reporter retranslator.
    API Tkontrol API Tkontrol Integrated the Tkontrol retranslator.
    Teltonika Teltonika FMC125 Improved the io_109 parameter registration.
    Queclink Wireless Solutions Queclink GV355CEU Added registration for the RESP:GTCAN packet with the following parameters:
    report_head, report, buffer, msg_type_name, can, dev_type, proto_ver, can_ign_key, can_total_distance, tco_distance, can_total_fuel, can_eng_rpm, can_speed, can_eng_cool_temp, can_range, can_acc_pedal_press, can_total_eng_hours, can_total_driv_time, can_total_eng_idle, can_total_idle_fuel, can_tacho_inf, tco_activity_type1, tco_activity_type2, can_detail_inf, can_lights, can_doors, can_total_veh_ovspd, can_total_eng_ovspd, can_eng_cold_starts, can_eng_all_starts, can_tacho_ovspd, can_tacho_motion_sign, can_tacho_driv_direction, can_ain1, can_eng_braking_factor, can_pedal_braking_factor, can_total_accel_kickdowns, can_total_effective_eng_speed_time, can_total_cruise_cntrl_time, can_total_accel_kickdown_time, can_total_brakes, can_reg_number, can_exp_info, tacho_info_expand.
    Queclink Wireless Solutions Queclink GV75M Changed the parameter name from bat_status to ext_pow_supply.
    Queclink Wireless Solutions Queclink GV75 LTE Added the ext_pow_supply parameter.
    Suntech Suntech ST8310U Improved the command-sending functionality.
    Toptraking Toptraking G50L Improved the set_report_interval TCP command.
    Shenzhen Cantrack Technology Co., Ltd Cantrack G08L Added decoding for the 0x0701 command type answer.
    Shenzhen Cantrack Technology Co., Ltd Cantrack G06L Added the ACK for heartbeat messages.
    TOPFLYTECH Co., Limited PioneerX 101, HeroX 100 - Improved decoding for the 0x252523 message type.
    - Added the 1wire_device_type parameter.
    BS Technotronics BSTPL 17IS CAN Improved the max_cell_volt parameter registration.
    Assistant Telematics AVT110 - Added ACK for the CVS, CMI, and VER packets.
    - Improved time registration for multi-package message decoding.
    Assistant Telematics AVT20 Improved the multi-package message decoding functions.
    Naturelink Naturelink NL02 Added the following parameters:
    ble_N_rssi, ble_N_hw_ver, ble_N_fw_ver, ble_N_status, limp_mode, alco_alarm, alco_value, alco_units, escort_N_rssi, escort_N_mode, escort_N_event, escort_N_angel, escort_N_temp, escort_N_pwr_int.
    CARVIS All devices Removed _video_N commands from vrt_commands.
    Streamax Technology Streamax AD PLUS 2.0 Improved the GETSUPPORTSERVICE request function.
    6 January - 10 January, 2025
    Manufacturer Device/Application Updates
    Assistant Telematics ATL100 Renamed MTL100 to ATL100.
    30 December, 2024 - 3 January, 2025
    Integrations
    Totarget GW005 Added support for the GW005 device.
    Shenzhen Ultravision Technology Co., Ltd. Ultravision B series Added support for the Ultravision B series device.
    23 December - 27 December, 2024
    Assistant Telematics AVT110 Changed time registration to use the Generated Time parameter from the data packet.
    Jimi IoT (Concox) LL704 Added decoding for the 0xA1 packet type without specific parameters.
    Queclink Wireless Solutions Queclink GV350CEU Added decoding for the GTTPM packet type into the following parameters:
    - tire_position_N
    - tire_bat_volt_N
    - tire_press_N
    - tire_temp_N
    - tire_status_N
    - tire_time_out_N
    - tire_rf_quality_N
    - tire_ref_press_N
    Queclink Wireless Solutions Queclink Track Protocol Changed time registration to use the Generated Time parameter from the data packet.
    Streamax Technology Streamax AD PLUS 2.0 Improved the algorithm for downloading videos.
    16 December - 20 December, 2024
    Integrations
    STONKAM CO.,LTD Stonkam MDVR Integrated the Stonkam MDVR device.
    Queclink Wireless Solutions Queclink Track Protocol Added registration for the 0d7, 0d17, and 0d43 Data IDs in the following parameters:
    - io_state
    - rf433_state
    - current_working_mode
    Queclink Wireless Solutions Queclink GV58CEU Added decoding for the GTALM packet type into alm_N parameters. To use this functionality, enable the Parse GTALM parameters option in the device configuration in the unit properties (icon ).
    Queclink Wireless Solutions Queclink GL50B LITE Added the report_type_gtgeo parameter.
    Queclink Wireless Solutions Queclink GV350CEU Added support for saving multiple CAN parameters in hexadecimal format.
    Queclink Wireless Solutions Queclink GV50CEU Added decoding for the GTASC packet type for ASCII sending type.
    Hikvision Hikvision AE-DI2032-G40, Hikvision AE-DI5042-G4 Fixed negative coordinate values for the 0x0801 package type.
    Ruptela Ruptela Pro5 Lite Added support for the KNOV keyboard via transparent channel. To get data from the KNOV keyboard, enable the KNOV keyboard by transp option in the device configuration in the unit properties (icon ).
    Ruptela Ruptela Trace5 Added support for the UDP channel for the output_on and output_off commands.
    Jimi IoT (Concox) JC450 Added support for GS-601 via transparent channel. To get data from GS-601, enable the GS-601 by transparent option in the device configuration in the unit properties (icon ).
    Shenzhen Esino Technology ES-GP06 Fixed decoding for the status parameter.
    9 December - 13 December, 2024
    Integrations
    Hikvision Hikvision AE-DI2032-G40 Added support for the Hikvision AE-DI2032-G40 device type.
    Streamax Technology Streamax AD PLUS 2.0 Added registration for the CONFIGMODEL packet with the following parameters:
    - camt
    - cast
    - cp
    - cport
    - ctport
    - cuport
    - en
    - etls
    - gpsex
    - gpss
    - lgk
    - mport
    - mtport
    - muport
    - nbb
    - nwt
    - ruf
    - ms
    - cs
    TechnoKom Avtograph Added support for stationary coordinates. To use the Coordinates for stationary units functionality, enter the coordinates in the corresponding field in the device configuration in the unit properties (icon ).
    Shenzhen Coban Electronics GPS103-B Added registration for the battery parameter.
    Think Power Think Power TL-904D Added support for 0xA2 and 0x29 packet types with the following parameters:
    - sa_slot
    - sa_direction
    - sa_status
    - sa_circle
    - total_millage
    - total_work_tm
    ControlT ControlT Improved the ControlT retranslator.
    Sensata INSIGHTS (Xirgo Global - BCE) BCE IOTM Improved the algorithm for constructing tachograph file names for BCE devices.
    Assistant Telematics MTL100 Improved registration for the 1wire_temp_id parameter.
    Suntech Suntech ST449 Added support for receiving messages via LoRaWAN.
    Gosuncn Gosuncn GT117, Gosuncn GD201 Added support for FOTA functionality. Firmware can now be updated from Wialon using the Request MCU update command.
    Sukarne Sukarne Improved the Sukarne retranslator by converting event message type values to integers.
    2 December - 6 December, 2024
    AOVX AOVX V-Series Added support for Getscale GS-601 via transparent channel. To get data from the RFID reader, enable the Use Getscale GS-601 option in the device configuration in the unit properties (icon ).
    Globalstar Globalstar SmartOneC Changed the default state of the Used firmware version 2.1 device configuration property to active.
    Queclink Wireless Solutions Queclink GV620MG Added support for registering BLE accessory MAC addresses in raw format. To save bt_mac_N in the corresponding format, enable the Raw MAC-address format option in the device configuration in the unit properties (icon ).
    Queclink Wireless Solutions Queclink GV50CEU Improved decoding for the GTHBE packet.
    LinkedCore Linkedcore Improved decoding for the driver_id parameter.
    Teltonika Teltonika TRB245 Added the option for receiving data via MQTT.
    GoTrack G400 Improved longitude registration.
    Jimi IoT (Concox) JC261 Added support for naming video files based on events detected by the device.
    NAL Research Shout Nano Added the emergency_clear command type to stop the emergency alarm.
    25 November - 29 November, 2024
    Jimi IoT (Concox) JC450 - Added support for the Getscale GS-404 via transparent channel. To get data from the RFID reader, enable the Getscale GS-404 by transparent option in the device configuration in the unit properties (icon ).
    - Added decoding of the peripheral data packet 0x2007 into the peripheral_{peripheral_id}_val parameter.
    Queclink Wireless Solutions Queclink GV350CEU Added parsing for the GTBAR packet with the following parameters:
    - bt_index
    - bt_type
    - bt_model
    - bt_access_mask
    - bt_mac
    - bt_status
    - bt_vers
    - bt_pgn_N
    - bt_pgn_data_N
    - mcc
    - mnc
    - lac
    - cell_id
    - gnss_trigger_type
    Queclink Wireless Solutions Queclink GV620MG Added parsing for the GTBID and GTBIE packets with the following parameters:
    - bt_detected_count
    - bt_total_frame
    - bt_frame_index
    - bt_beacon_number
    - bt_model_id_N
    - bt_mac_N
    - bt_pwr_int_N
    - bt_rssi_N
    - bt_temp_N
    - bt_nearest_mac
    - bt_nearest_rssi
    Teltonika Teltonika FMB130 Added decoding for the io_282 parameter into dtc_fault.
    Sensata INSIGHTS (Xirgo Global - BCE) BCE FM Blue Improved the decoding algorithm to prevent rollover value errors after January 4, 2025.
    18 November - 22 November, 2024
    Integrations
    ERM Advanced Telematics IoTLink Shadow Integrated the IoTLink Shadow device.
    Here’s the continuation of the table with these additional entries:
    Howen Technologies Hero-ME41-04 Added decoding for the following parameters:
    - driver_data
    - bluetooth_data
    Multi Portal RST-TG100 Added support for TCP connection.
    Queclink Wireless Solutions Queclink GV55W Added decoding for the mileage parameter in the following packet types:
    - GTEPS
    - GTRTL
    - GTDOG
    - GTIGL
    Ruptela Ruptela Pro5 Lite Improved parsing for TPMS (Tire Pressure Monitoring System) data.
    Gosuncn Gosuncn GT300 Improved the set_device_parameters command to allow setting multiple parameters at once.
    Linkedcore all devices Added registration of the Driver ID field (0xf9) to the driver_id parameter.
    11 November - 15 November, 2024
    Integrations
    Manufacturer Device/Protocol/Retranslator Updates
    Intelbras Moovsec API Added support for the Moovsec protocol.
    AI27 predictive inteligence AI27 Added support for the AI27 retranslator.
    Autoseeker Electronics AT-17 Integrated the AT-17 device.
    Howen Technologies Hero-ME41-04 - Improved coordinates decoding from the 0x1092 message type.
    - Added decoding for the iccid parameter.
    Howen Technologies Hero-ME41-02 Improved audio and video synchronization for Howen devices.
    Galileosky all devices Improved the decoding algorithm for all devices.
    Milesight Milesight IoT Added the ability to send commands to the gateway server.
    Naturelink Naturelink NL02 Added decoding for the following parameters:
    lls_net_number, lls_temperature, lls_level, lls_frequency, escort_fuel_d2_number, escort_fuel_d2_fuel_level, escort_fuel_d2_battery_voltage, escort_fuel_d2_temperature, eye_sensor_realtime_mac, eye_sensor_rssi, eye_sensor_temperature, eye_sensor_humidity, eye_sensor_mov_sensor_state, eye_sensor_mov_sensor_angle, eye_sensor_battery_voltage, pulse_speed, mcu_temperature, eddystone_realtime_mac, eddystone_rssi, eddystone_calibrated_tx, eddystone_namespace, eddystone_instance, eddystone_rfu, eddystone_prefix, eddystone_url, eddystone_tlm_ver, eddystone_tlm_vbatt, eddystone_tlm_temp, eddystone_tlm_ad_pdu_c, eddystone_tlm_on_time, eddystone_ephemeral_id
    Globalstar Globalstar SmartOneC Added support for the SmartBridge fuel level sensor via transparent channel.
    To get data from the sensor, enable the User data as SmartBridge FLS option in the device configuration in the unit properties (icon ).
    Queclink Wireless Solutions GV501LG Improved decoding of messages with unfixed coordinates.
    Queclink Wireless Solutions Queclink GV355CEU Added decoding for the GTTPM data packet with the following parameters:
    - tire_bat_volt_N
    - tire_press_N
    - tire_temp_N
    - tire_status_N
    - tire_position_N
    4 November - 8 November, 2024
    Integrations
    Manufacturer Retranslator Updates
    MappointAsia MappointAsia Added the MappointAsia retranslator.
    NEWTEC VIRLOC VL08 Added registration for command answers.
    Think Power Think Power TL-904D Added the following parameters:
    - ibutton_bcr
    - scan_id
    Queclink Wireless Solutions Queclink GV300CAN Added decoding for the GTCRA packet type. No new parameters were added.
    Queclink Wireless Solutions Queclink GV58CEU Added registration for the card_id parameter for the GTERI packet type.
    Gosuncn Gosuncn GD201 Added support for 0x04 Major and 0x0D Minor data types with the following parameters:
    - accel_x
    - accel_y
    - accel_z
    - rpm
    - tm_interval
    - vehicle_speed
    - data_type
    - source
    - sensor_study_status
    - is_from_past
    - hacc
    - navigation_status
    See parameter descriptions.
    Jimi IoT (Concox) JC450 Added support for the command response in the Chat with driver window.
    Jimi IoT (Concox) JC400D Improved functionality for receiving video from the device.
    Howen Technologies Hero-ME41-04 Improved message time registration for the 0x1051 message type.
    28 October - 1 November, 2024
    Hikvision Hikvision AE-DI5042-G4 Added options for fixing negative latitude and longitude. If the device sends incorrect latitude or longitude values, enable the Always use negative latitude value or Always use negative longitude value option in the device configuration in the unit properties (icon ).
    Galileosky Galileosky 10 Added Galileosky tags 0x253 (parameter ibutton64) and 0x254 (parameter ibutton64_2) to the Registration ibutton as hex option in the device configuration in the unit properties (icon ).
    Jimi IoT (Concox) Concox JM-LL01 Improved time value parsing for 0x33 and 0x34 data packets.
    Peak Tech Power Limited L19 Added the BP40 Send Text Message option for the Send command with custom parameter command.
    Toptraking Toptraking G50L Added registration of 0x82, 0x83, and 0x94 packets for the following parameters:
    - charge_completed
    - charge_connected
    - vibr_alarm
    Shenzhen HHD Technology GPS Padlock G-508 (New Protocol) Improved the platform_cmd command description.
    Teltonika Teltonika FMC650 Improved video request from the DualCam.
    Queclink Wireless Solutions Queclink CV100LG Improved video request from the device.
    ERM Advanced Telematics StarLink Tracker Improved decoding of edome fuel level sensor messages.
    WanWayTech WanWay GS10G Improved decoding of BLE sensor MAC addresses.
    Think Power Think Power TL904M Improved the process for sending commands from the server.
    Verizon Connect Inoslv V8 Added new parameters:
    distance_total, distance_cruise, fuel_con_total, fuel_cons_pto, fuel_cons_idle, fuel_cons_driving, fuel_cons_cruise, time_cruise, time_pto, time_idle, time_driving, engine_hours, version_num, engine_status, max_engine_speed, max_veh_speed, inc_distance, inc_fuel_cons, average_fuel_lvl, max_acc_pedal, clutch_pedal, min_veh_speed, fuel_eco_range, time_eco_range, distance_eco_range, breaks_num, harsh_breaks_num, harsh_acc_num, time_high_rpm, time_high_temp, fuel_high_rpm, distance_high_rpm.
    21 October - 25 October, 2024
    Integrations
    STONKAM CO.,LTD ADA44 Integrated the ADA44 device.
    MITRE Cursor on Target Integrated the Cursor on target protocol.
    Sitrack Sitrack Integrated the Sitrack retranslator.
    Vanguard IoT Vanguard Asset Tracker Integrated the Vanguard Asset Tracker.
    Onboard Eletronics OnBoard Eletronics OnLink Integrated the OnBoard Eletronics OnLink protocol.
    eTrans Solutions DARSH_Lite Integrated the DARSH_Lite device.
    Teswell Teswell 830X Added decoding of temperature and humidity sensors (0xE2 packet) with the following parameters:
    - humidityN
    - device_humidity
    - device_temp
    - tempN
    - air_qualityN
    Meitrack Meitrack T622G Added support for Iridium channel connection.
    Queclink Wireless Solutions Queclink GV57CG Improved decoding of the GTERI packet type.
    Gosuncn Gosuncn GT300 Added support for the set_device_parameters command.
    TOPFLYTECH Co., Limited Topflytech TLW2-12BL, Topflytech T8803+ Improved decoding of BLE sensor data.
    Sensata INSIGHTS (Xirgo Global - BCE), Caiquén BCE IOTM, Caiquén 212 Added support for the Caiquén 212 accessory via transparent channel.
    To get data from Caiquén 212, enable the Use Caiquén 212 option in the device configuration in the unit properties (icon ).
    ATrack ATrack AK500 Added BLE data decoding with the following parameters:
    - ble_mac_N
    - rssi_N
    - humidity_N
    - temp_data_N
    - type_N
    - mag_data_N
    Iridium Iridium Edge Pro Improved the decoding algorithm.
    Teltonika Teltonika FMB140 Added io_10828 parameter to the decoding algorithm.
    Teltonika Teltonika FMC650 Improved registration of DDD file names.
    Teltonika Teltonika FMC125 Added support for the Uface 5 by RS-232 Delimiter accessory.
    To get data from Uface 5, enable the Uface 5 by RS-232 Delimiter mode option in the device configuration in the unit properties (icon ).
    Think Power Think Power TE604E Added registration of the sos parameter for the 0x10 SOS record type.
    14 October - 18 October, 2024
    Integrations
    T-Zone WF501B Integrated the WF501B asset tracker.
    GoTrack G400 Integrated the G400 asset tracker.
    Queclink Wireless Solutions Queclink Track Protocol Added the following parameters:
    - tamper_curr_status
    - tamper_prev_status
    - tamper_prev_dur
    Howen Technologies Hero-ME41-04 Added support for the 0x4040 subscription upload model functionality.
    To choose the message upload model, enter the value into the 0x4040 subscription upload model field in the device configuration in the unit properties (icon ).
    BoShiJie Technology EG01G Improved parameter naming.
    LinkedCore LinkedCore Added support for parsing Escort DU parameters. The following parameters are now available:
    - ble_escort_dev_type_N
    - ble_escort_sens_mode_N
    - ble_escort_rpm_N
    - ble_escort_evnt_notif_on_N
    - ble_escort_evnt_notif_cnt_N
    - ble_escort_tilt_angle_N
    - ble_escort_tot_rev_cnt_N
    - ble_escort_temp_N
    - ble_escort_roll_N
    - ble_escort_pitch_N
    - ble_escort_pwr_int_N
    - ble_escort_fw_vers_N
    - ble_escort_content_type_N
    - ble_escort_name_N
    - ble_escort_rssi_N
    7 October - 11 October, 2024
    Teltonika FMB140 Fixed the registration of the following parameters:
    - beacon_count
    - beacon_nearest_id
    Teltonika FMB640 Added decoding of responses for the query_pos command.
    Toptraking Toptraking G50L Added the iccid parameter. See parameter description.
    Assistant Telematics AVT110 Added parsing of +VER, +CVS, and +CMI packets with the the following parameters: protocol_ver, can_car_model_id, can_car_name, can_sync_status, firmware_ver, hardware_ver, modem_software_ver, can_version_num, can_serial.
    Streamax Technology Streamax X3-H0402 Improved the decoding algorithm for the door status change.
    Baita Tecnologia Baita MAC 4G Added the reset command.
    EGTS EGTS Added parsing for EGTS_SR_DISPATCHING packet into the following parameters: route_num, direction.
    BoShiJie Technology EG01G Improved decoding algorithm for parsing sub-packets 0x0121 and 0x0122.
    A-Telematics AT08 Added parsing for 0x1B packets with the following parameters: ad1, ad2.
    DCT Syrus Pegasus Gateway Added the flow_meter_display_state parameter.
    Lynkworld Lynkworld LW2G-4A Added the bat_pwr parameter registration.
    SGBras SGBras keyboard Added the sgbras_journey_num parameter.
    E3Innovations Oy E3Blue Improved the data request frequency for location packets to 30 seconds.
    Queclink Wireless Solutions Queclink Track Protocol Added registration for the following parameters:
    - intern_temp
    - intern_temp_tm
    - battery_basic_status
    - battery_voltage
    - battery_percent
    - battery_charging
    Queclink Wireless Solutions Queclink GV310LAU Added the ign parameter for GTIGN and GTIGF packet types.
    Great-Will GAT23 Added the tkstar_light_alarm parameter.
    Meitrack Meitrack T399 Series Added the rfid_hex parameter.
    30 September - 4 October, 2024
    Integrations
    Here’s the continuation of the table with this final entry:
    Kirsen Global Security Kirsen API Integrated the Kirsen API asset tracker.
    Teltonika Teltonika ADAS Improved video file receiving functionality.
    PCL PCL109 ADAS_DMS_BSD Dashcam Improved video file receiving functionality.
    Queclink Wireless Solutions Queclink GV350CEU Added the bt_raw_data_dec parameter.
    Queclink Wireless Solutions Queclink GV55S Added the following parameters:
    - svr_state
    - ghost_mac
    - svr_append_info
    Jimi IoT (Concox) JM-VL03M Added the mileage parameter.
    Galileosky All device types Added parsing for device SMS responses.
    Jimi IoT (Concox) PL200 - Added parsing for device command responses.
    - Added the following parameters:
    - content
    - encoding
    - server_flag
    Garmin inReach MINI Added the update_tracking_status command.
    Megastek Technologies Megastek MT60X Added coordinate registration for messages with “V” GPS fix.
    23 September - 27 September, 2024
    Integrations
    Global Satellite Engineering GSatSolar Integrated the GSatSolar asset tracker.
    Digital Matter Telematics Barra Edge Added the following commands:
    resync_device_slots, reboot, set_operat_mode, set_digital_output, immobilise, reset_device_stats.
    Queclink Wireless Solutions Queclink GV57MG Added parsing of the +RESP:GTALM packet with the following parameters:
    alm, buffer, current_packet, dev_type, msg_type_name, proto_ver, report, report_head, total_packets.
    Teltonika Teltonika FMB640 Added SMS parsing for Teltonika FMB640 in Wialon Hosting and Local versions 2204 and 2304.
    iTR iTR 270 Added the following parameters:
    - rpm
    - login_tm
    - ibutton
    - total_mileage
    - freq
    - temp
    WanWayTech WanWay GS10G Added the following parameters:
    - bid_db
    - nid_db
    Iridium Iridium Edge Solar Added speed and course data registration for packets 0x03, 0x04, and 0x05.
    Queclink Wireless Solutions Queclink GV310LAU Added acc_x, acc_y, and acc_z parameters for the +RESP:GTHBE packet.
    16 September - 20 September, 2024
    Integrations
    Tramigo Tramigo TF150 Integrated the Tramigo TF150 device.
    BoShiJie Technology EG01G Added the packets 0x0702, 0x0900 and the additional info packets 0x0115 (can be copied from jt808), 0121, 0122, 0123, 0124, 0125, 0126, 0127 with the following parameters:
    tco_insert_card, tco_insert_time, tco_ic_card_read, tco_driver_name, tco_qual_cert_code, tco_notif_body_name, tco_cert_term, mileage, manufacturer_data_N, fuel_tank_lvl_N, oil_level_N, temp_N, state_N, manufacturer_data, fuel_tank_height, oil_volume_level, vbat, temperature, accel_(x/y/z), fuel_meter_stability, fuel_level_stability, cover_sensor, channels, mac_N, device_pitch_N, device_roll_N, motion_status_N, motion_event_count_N, mark_N, fuel_meter_data_type, oil_perc, oil.
    Geometris whereQube OBD Added support for JSON file parsing. To get data, enable the Report formats configuration file (.json) option in the device configuration in the unit properties (icon ).
    Assistant Telematics AVT110 - Improved UART1 info data decoding.
    - Added the rto_command command.
    WanWayTech WanWay GS10G Improved the BLE sensors data parsing.
    Queclink Wireless Solutions Queclink GB100MG Added decoding for +RESP:GTBMC and +RESP:GTBML packets with the following parameters:
    m1000_mac, command, result, scanned_mac_N, arm_state, enrolled_users_num, enrolled_user, connected_key, starter_relay, m1000_mode, auto_arm_delay_time, connection_status, owner_mac.
    Baita Tecnologia Baita MAC 4G Added support for speed decoding in km/h. To use this feature, enable the Convert speed from knots to km/h in the device configuration in the unit properties (icon ).
    Gosuncn Gosuncn GD201 Added parsing for 0x040D packet with the following parameters:
    accel_x, accel_y, accel_z, rpm, tm_interval, vehicle_speed, data_type, sensor_study_status, navigation_status, hacc.
    Toptraking Toptraking G50L - Improved time parsing for packets 0x18, 0x19, 0x1A.
    - Improved ACK response for packets 0x01, 0x10.
    Blueberry Technology GT06 Added packets 0x12, 0x13 with the following parameters:
    - sensor_percent
    - temp
    - battery
    - sensor_type
    TOPFLYTECH Co., Limited KnightX 100 Improved SOS message detection.
    9 September - 13 September, 2024
    Suntech Suntech ST4305 Added support for decoding Autosender AS0721 parameters.
    For conversion, enable the Autosender AS0721 by transpt option in the device configuration in the unit properties (icon ).
    Kingwo Kingwo MT Series Added command response registration.
    WanWayTech WanWay GS10G Added BLE sensor decoding with the following parameters:
    - nid
    - bid
    - mac_N
    - temp_{mac}
    - pwr_int_{mac}
    - battery_{mac}
    - alarm_{mac}
    - adv_{mac}
    - rssi_{mac}
    - door_{mac}
    - humidity_{mac}
    - light_{mac}
    BlackRock IOT BR1201 Added oil data parsing with the following parameters:
    - oil_level1
    - oil_level2
    Queclink Wireless Solutions Queclink GV58LAU Added parsing for the ign and motion_status parameters.
    Micron Micron PT102 Improved the time decoding functionality.
    Ruptela Ruptela Trace5 Added the iccid parameter registration.
    2 September - 7 September, 2024
    Integrations
    E3Innovations Oy E3Blue Integrated the E3Blue device.
    Queclink Wireless Solutions Queclink GV55 Fixed the issue with ign and hourmeter parameters disappearing.
    Toptraking Toptraking G50L Added time synchronization functionality (0x30 packet type).
    Assistant Telematics MTL100, AVT110 Added virtual command channel.
    Milesight Milesight IoT Added the tamper_status parameter. See parameter description.
    Queclink Wireless Solutions Queclink GV56 Added the ign parameter for ERI packet.
    26 August - 30 August, 2024
    Sascar Sascar Improved the connection type to HTTPS protocol with TLS v1.2.
    Howen Technologies Hero-ME41-04 Added the following parameters: geofence_status, geofence_threshold.
    Teltonika Teltonika FMC125 Improved the decoding of Getscale GS-404 data supported via transparent channel. The parameter gs_404_card_id_dec is decoded as an unsigned integer.
    Ruptela Ruptela Pro5 Lite Added support for parsing text data from the SGBras keyboard. To get text data from SGBras, enable the SGBras text keyboard by transp option in the device configuration in the unit properties (icon ).
    Meitrack Meitrack P99G Added the following parameters: work_count, version, work_mode, move_state.
    Milesight Milesight IoT Added the following parameters: gpio_1, gpio_2, valve_1, valve_2, ec, moisture, pressure, geo_status, motion_status, illumination, gpio_input_1, gpio_input_2, gpio_input_3, gpio_input_4, gpio_output_1, gpio_output_2.
    Streamax Technology Streamax X3-H0402 Added the universal custom command (universal_command) for changing configuration parameters.
    Micron Micron PT102 Improved the time decoding.
    Hikvision Hikvision AE-DI5042-G4 Improved the decoding of south latitude coordinates.
    19 August - 23 August, 2024
    Integrations
    Milesight Milesight IoT Integrated the Milesight IoT protocol.
    SHENZHEN THINK POWER TECHNOLOGY Co., LTD. TL904M Integrated the TL904M device.
    Changes and improvements
    Queclink Wireless Solutions Queclink GV350CEU - Added parsing of +RESP:GTCLT including the following parameters: alm_mask1, alm_mask2, alm_mask3, can_acc_pedal_press, can_amb_temp, can_detail_inf, can_doors, can_dtc_num, can_eng_braking_factor, can_eng_cool_temp, can_eng_rpm, can_eng_torq, can_exp_info, can_fuel_consumpt, can_fuel_level_p, can_ign_key, can_lights, can_pedal_braking_factor, can_range, can_speed, can_tacho_driv_direction, can_tacho_inf, can_tacho_motion_sign, can_tacho_ovspd, can_total_distance, can_total_fuel, cell_id, clt, dev_type, gps_acc, group_id, lac, mcc, mnc, msg_type_name, proto_ver, report, report_head.
    - Improved CAN data parsing.
    Jimi IoT (Concox) JC450 Improved server ACK.
    Jimi IoT (Concox) VL101G Improved the decoding algorithm.
    Ministry of Transport of the People’s Republic of China JT808 Added the following parameters: iccid, extended_alarm_status, extended_alarm_status_2, pwr_ext, pwr_int, imei.
    Queclink Wireless Solutions Queclink GV55W, Queclink GV58LAU Improved mileage parameter decoding.
    Suntech Suntech ST4305 Added support for Connect-Bus via transparent channel. To get data from RST-TG100 enable the Connect-Bus by transparent option in the device configuration in the unit properties (icon ).
    Jimi IoT (Concox) VL106 Fixed parsing issues.
    Queclink Wireless Solutions GV355CEU Added ACK response for the TCA app upon successful authorization.
    Queclink Wireless Solutions GV55 Improved state parameter decoding.
    Shenzhen Cantrack Technology Co., Ltd JT808 Improved the send_message command type.
    12 August - 17 August, 2024
    Integrations
    Vacron GMServer Gateway Integrated the GMServer Gateway.
    ControlT Tyrecontrol TC PRO Integrated the Tyrecontrol TC PRO device.
    Nortac Defence Whisper Nortac Defence Integrated the Whisper device.
    Queclink Wireless Solutions Queclink CV200XEU/XNA Added parsing of GTDSA packets for device status alerts report, including the following parameters:
    - alm_type: Type of alarm:
    - 101 SIM card removed.
    - 102 SIM card faulty.
    - 103 SIM card locked by PIN.
    - 104 SIM card locked by PUK.
    - 105 SIM card normal.
    - 200 TF card removed.
    - 201 TF card cannot be accessed.
    - 202 TF card formatting.
    - 203 TF card normal.
    - 300 Front camera normal.
    - 301 Front camera faulty.
    - 400 Interior camera normal.
    - 401 Interior camera faulty.
    - 402 Interior camera removed.
    Jointech Jointech JT701 Added the query_pos command for retrieving the current device position.
    Jimi IoT (Concox) JC400 Added parsing of fuel sensor data with the following parameters:
    - fuel_sens_val_{fuel_sensor_id} Sensor value.
    - fuel_sens_units_{fuel_sensor_id} Sensor value unit:
    - 01 Height.
    - 02 Percentage.
    - 03 Voltage.
    Jimi IoT (Concox) JC261 Improved timestamp decoding functionality.
    TOPFLYTECH Co., Limited Topflytech Pioneerx 100 Improved peripheral device decoding.
    WanWayTech WanWay GS10G Improved the temp1wire and humidity1wire parameter decoding.
    Ruptela Ruptela HCV5 Added the “Cipia by transparent” checkbox to support for Cipia device by transparent channel.
    Streamax Technology Streamax AD PLUS 2.0 Added OBD parameters decoding functionality.
    05 August - 09 August, 2024
    Manufacturer Device Updates
    Galileosky Galileosky 7x Added registration of float user_d parameters as user_dN_fl.
    Teltonika Teltonika FMC650 Added ACK for the file transfer status command (CMD ID 0x0005).
    Jimi IoT (Concox) JM-LL303, JM-LL301, Concox JM-LL01, PL200, Concox AT1 Added the following parameters for the heartbeat (0x36) packet type:
    - term_info:
    - Bit0: 1 - Set defense (locked), 0 - Cancel defense (unlocked).
    - Bit1: 1 - ACC on, 0 - ACC off.
    - Bit2: 1 - Charging with power, 0 - Charging without power.
    - Bit3-Bit5: Extended bits.
    - Bit6: 1 - Positioned, 0 - Not positioned.
    - Bit7: 1 - Cut off fuel/power, 0 - Connect fuel/power.
    - term_defense: 1 - Set defense (locked), 0 - Cancel defense (unlocked).
    - term_acc: 1 - ACC on, 0 - ACC off.
    - term_charge: 1 - Charging with power, 0 - Charging without power.
    - term_pos: 1 - Positioned, 0 - Not positioned.
    - term_fuel: 1 - Cut off fuel/power, 0 - Connect fuel/power.
    - voltage_level:
    - 0: No power.
    - 1: Battery extremely low.
    - 2: Battery very low.
    - 3: Battery low.
    - 4: Battery medium.
    - 5: Battery high.
    - 6: Battery extremely high.
    - cellular_signal_strength:
    - 0: No signal.
    - 1: Extremely weak.
    - 2: Weak.
    - 3: Good.
    - 4: Strong.
    - lang_extended_port: Language/extended port status.
    ORBCOMM Orbcomm ST 9100 Added generate_report command.
    Suntech ST4345, ST940, ST4340, ST3300, ST4300 Added display of command responses.
    Added a property to activate this functionality.
    Sensata INSIGHTS (Xirgo Global - BCE) BCE FMS500 StCAN Added the Substitution coordinates functionality.
    Queclink Wireless Solutions Queclink GB130MG Added the following parameters for the GTALM packet type:
    - total_pac Total number of +RESP:GTALM messages.
    - curr_pac Sequence number of the current +RESP:GTALM message.
    - config Current configuration of the device.
    Queclink Wireless Solutions Linkedcore, Linkedcore LV6x Series, Linkedcore LG2x Series, Linkedcore LA7x Series Added support for ESCORT DU BLE message decoding.
    Teltonika Teltonika FMC650 Added rfid_value parameter.
    22 July - 25 July, 2024
    Gosafe Gosafe G16S Added support for CAN-Logistic via transparent channel.
    Queclink Wireless Solutions Queclink CV200XEU/XNA Improved the video stop command.
    Queclink Wireless Solutions Queclink GV55W Improved the GTFRI message type decoding for the devices with version 7.00 FW and above.
    TAIGA IoT TaigaIoT Chirpstack v4 Improved data registration.
    Teltonika Teltonika FMC650 Added weight sensor support via transparent channel.
    TOPFLYTECH Co., Limited TopflyTech TLP2-SFB Added the following parameters for BLE fuel level sensor:
    - ble_sens_id BLE Fuel level sensor ID.
    - ble_{sensor_id}_pwr Sensor battery voltage in V.
    - ble_{sensor_id}_fuel_lvl Fuel level (ADC value).
    - ble_{sensor_id}_temp Temperature in ℃.
    - ble_{sensor_id}_state State (0: normal, 1: filing state, 2: leaking state).
    - ble_${sens_id}_rssi RSS value in dBm.
    WanWayTech WanWay GS10G Added the following temperature and humidity parameters:
    - temp_{sensor}_$i Temperature in ℃.
    - humidity_{sensor_id}_$i Humidity in %.
    15 July - 19 July, 2024
    LEVEL Systems (Positrex) TotalTracker Added support for the 0x2E GREEN record type, which includes position data, information from GSM/LTE, and data from internal sensors.
    Queclink Wireless Solutions Queclink GL320MG, Queclink GV500, Queclink GB100MG, Queclink GB130MG, Queclink GV50M, Queclink GV53MG, Queclink GV350M, Queclink GL30MG, Queclink GV57MG Added the firmware uploading functionality from Wialon Queclink.
    Queclink Wireless Solutions Queclink GB130MG Added the GTBTI packet decoding with the following parameters:
    - bt_name Bluetooth name.
    - bt_state Bluetooth state (0: is not connected; 1: connected).
    - connected_dev_name_N The name of the connected perepheral device.
    - dev_mac_N The MAC address of the connected device.
    - dev_role_N The role type of the peripheral device (0: Master; 1: Slave).
    - real_tm_state Indicates whether Ghost Data is real time data or historical data read from Ghost.
    - ghost_battery The current volume of the backup battery as a percentage.
    - ghost_state Bitwise mask defining the status of the Ghost device. 0 indicates “normal status,” and 1 indicates “a specific abnormal status is detected.” For specific details of each bit, please see below.
    - Bit 0: Reserved.
    - Bit 1: GNSS fix failure.
    - Bit 2: Fake cell detected.
    - Bit 3: Low battery warning.
    - Bit 4: Failure to get RTC time.
    - Bit 5: SIM card error.
    - Bit 6: GSM unavailable.
    - Bit 7: GPRS unavailable.
    - Bit 8: Failure to connect to backend server.
    - Bit 9 – Bit 14: Reserved.
    - Bit 15: Communication error between MCU and BB.
    - ble_mac BLE beacon MAC address.
    - rep_interval_pwr_on Time interval for GPS position report while ignition is on, in seconds.
    - rep_interval_pwr_off Time interval for GPS position report while ignition is off, in seconds.
    - alarm_for_heading_angle Alarm when the heading angle threshold is exceeded. Heading angle alarm state: 1 - detected 0 - not detected.
    7 July - 13 July, 2024
    Integrations
    Manufacturer Device/Retranslator Updates
    iTriangle BHARAT101PLUS-4G Integrated the BHARAT101PLUS-4G device.
    UNIGIS UNIGIS Integrated the UNIGIS retranslator.
    Manufacturer Device/Devices/Protocol Updates
    ATrack ATrack AK11 Added a checkbox to hide DTC values in the chat with drivers.
    Baita Tecnologia Baita MAC 4G Added a command to lock/unlock the equipment.
    ERM Advanced Telematics StarLink Tracker Added support for the eDome LLS sensor with the following parameters:
    - edome_ign_on_sensor_macN MAC address of the sensor when the ignition is on.
    - edome_ign_on_fuel_levelN Amount of fuel (liters/percentage) when the ignition is on.
    - edome_ign_off_sensor_macN MAC address of the sensor when the ignition is off.
    - edome_ign_off_fuel_levelN Amount of fuel (liters/percentage) when the ignition is off.
    - edome_gps_time GPS date and time of fuel incidents(refueling/drain).
    Gosuncn Gosuncn GD201 Added the following parameters:
    - shock_value The sensor value when a shock event is detected (data_type:1293 Temperature warning, data_type:1294 Air pressure warning, data_type:1296 Ambient light detection warning).
    - motion_state Device is detected in/out movement state (0: Quit movement state, 1: Enter movement state).
    - workmode Current workmode (0x01: Workmode 1, 0x02: Workmode 2, 0x03: Workmode 3).
    Concox JM-LL301 Added the alarm_hex parameter.
    Jimi IoT (Concox) JM-LL303, JM-LL301, Concox JM-LL01, PL200, Concox AT1 Added the following parameters:
    - pwr_ext Battery voltage.
    - battery Battery voltage percentage.
    - prod_startup_status Product startup status.
    Jimi IoT (Concox) JM-VL502 Updated the OBD data registration format to data_id = value, where id is OBD parameter index.
    LinkedCore Linkedcore LA7x Series, Linkedcore LG2x Series, Linkedcore LV6x Series, Linkedcore Improved the BLE parameters decoding algorithm.
    Ministry of Transport of the People’s Republic of China JT808 Added the voltage parameter for voltage value upload in V.
    Queclink Wireless Solutions Queclink CV200XEU/XNA Improved the playback request functionality.
    Queclink Wireless Solutions Queclink GL320MG, Queclink GB130MG Added FOTA (Firmware Over-The-Air) support.
    Queclink Wireless Solutions Queclink Track Added the custom_msg command type.
    Queclink Wireless Solutions Queclink GV310LAU Added device responses in the chat with drivers.
    Ruptela Ruptela Pro5 Lite Improved transparent data transferring.
    Ruptela Ruptela Pro5 Lite, SGBras Added supported for the SGBras keyboard for Ruptela Pro5 Lite.
    SEEWORLD Technology Corporation Seeworld W18l Added the hdop parameter.
    Streamax Technology Streamax AD PLUS 2.0 Added support for the Bluetooth Escort fuel sensor.
    Technotrade LLC PTS-2 Added the following parameters:
    - start_datetime Date and time of the last in-tank delivery start.
    - start_product_height Product height in mm.
    - start_water_height Water height in mm.
    - start_temp Temperature in degrees Celsius.
    - start_product_volume Product volume in liters.
    - start_product_tc_volume Temperature-compensated product volume in liters.
    Teltonika Teltonika FMC650 Added io_10611 parameter registration.
    TOPFLYTECH Co., Limited Topflytech HeroX 100 Added the following parameters:
    - drv_beh_acc Behavior type (0: braking; 1: accelerating, 2: turning).
    - gps_data GNSS module and data state (Bit7=0 real-time data, Bit7=1 history data, Bit6=0 LBS data, Bit6=1 GNSS data, Bit5=0 GNSS working mode, Bit5=1 GNSS sleeping mode, Bit4~Bit0 Locked satellite count).
    30 June - 6 July, 2024
    WanWayTech WanWay GS10G Added the following LLS parameters:
    - oil_level Height of the oil level in mm.
    - adc1 Analog-in value in V.
