Tracker mode
The application is provided with a tracker mode for units with the WiaTag device type. This mode allows you to determine the courier location if no personal or vehicle tracker is available. When the mode is enabled, the application is constantly collecting and sending the location data to the server (or only when detecting the movement in the iOS version).
The battery consumption of the mobile device increases significantly in the tracker mode.
To enable the tracker mode, activate the switch in the Tracker mode section of the application settings (see more information about mode settings).
See also
