Preparation for Work
Before starting to work with Logistics, it is recommended to follow the steps below.
  1. In Wialon Local, activate the Orders service.
  1. Create a unit, if there is not any. Fill in the Carrying capacity and Effective capacity fields in its properties.
  2. Create a driver. Fill in the Phone number and the Mobile key fields.
  3. Assign the driver to the unit.
  4. Configure access rights and enable the required options in the CMS (see the section below).
  5. In the Logistics application, open the settings and select the resource to which the driver created in Wialon Local belongs.
In order for the application mobile and web versions to work correctly, the warehouses, orders, routes, drivers, and geofences should belong to the same resource.
Measurement system
The application uses the measurement system specified in the user settings in Wialon Local.
Address format
In the Address line of orders and warehouses, the components (for example, street, house, city, country) are arranged in the sequence specified on the Maps tab of the user settings in Wialon Local.
Access rights
Below are the rights required to work with the application.
TypeRightFunction in the application
Rights to the resource
View orders
Viewing orders
Create, edit, and delete orders
Creating, editing and deleting orders
Edit not mentioned properties
View detailed item properties
Creating, editing and deleting custom fields in orders
Creating, editing and deleting delivery requirements
Viewing and attaching geofences, planning by geofences
View geofences
Create, edit, and delete driversReceiving push notifications by the driver
Rights to units
View object and its basic properties
Request reports and messages
Use unit in jobs, notifications, routes, retranslators
Displaying units on the map and in lists
Request reports and messagesDisplaying tracks and executing reports
Use unit in jobs, notifications, routes, retranslatorsDisplaying units in the list when orders are distributed and units are replaced on the route
Rename objectRenaming units
View custom fields
Manage custom fields
Editing unit properties
If the user does not have the Request reports or messages or Use unit in jobs, notifications, routes, retranslators rights, the units become unavailable for use in the application.
Options in CMS
In order for the application to work correctly, the following options must be activated in the user properties in CMS:
  • Can create objects — to create orders (if the option is not enabled, the New order and the Import orders tabs are inactive);
  • Can send SMS — to edit the phone number in orders and select the phone number in the settings and orders (if the option is not enabled, the field for entering an SMS message text is inactive);
  • Can change settings — to edit the settings.
Configuring Logistics in Wialon Local
Below are the components required for working with Logistics in Wialon Local.
ComponentDescription
Screen package for DebianUse the apt-get install screen command to install the package.
Licence modules
Activate the following modules:
  • Basic Reports;
  • Drivers;
  • Gurtam Maps;
  • Logistics Module.
Separate DNS Create a separate DNS and direct it to the external IP of the server. In the administration system, indicate this DNS in the settings of the site of the Logistics type.
Hardware IPIn order for the Tracker mode option to work in the Logistics Local mobile application, the Hardware IP field should be completed in the system settings in the administration system.
CMS settingsIn CMS, you can configure Logistics in the same way as other applications. Indicate the created DNS in the URL field.
