Configuring Fleetrun in Wialon Local
To set up and run Fleetrun within Wialon Local (Wialon server solution), ensure the following requirements and configurations are met:
Required version of Wialon Local
The version of the Wialon Local server solution should not be older than three years from the date of its release.
Separate DNS
Create a separate DNS and forward it to an external IP server. In the administration system, specify this DNS with the type Fleetrun on the General tab of the site settings. The Fleetrun configuration in the CMS is similar to the configuration of other applications.
Licence modules
Activate the following modules: Basic Reports, Gurtam Maps and Fleetrun Module.
flespi token
For Fleetrun to work in Wialon Local, the correct flespi token must be specified in the administration system (it is specified and updated automatically).
Required services
In the billing plan or account of the user, activate the Fleetrun service and the access to the site indicated in the Base URL field of the site settings in the administration system.
Access to resources
Access to the following resources must be open on the server where Wialon Local is installed:
  • https://app-local.wialon.com (port 443)
  • 185.58.58.176
  • 185.58.58.158
  • 185.58.58.159
