Determining a trip status
This application is no longer supported, updated, or developed. The documentation is preserved for reference only.
The system can determine the following trip statuses: Business, Personal, Home-office-home.
The Private mode sensor is used to determine a trip type. It is configured on the Sensors tab in the unit properties of the monitoring system. The trip gets the Business status if zero sensor values have been received on the indicated time interval. If there is at least one non-zero value on the interval, the trip gets the Personal status.
A trip between home and office gets the Home-Office-Home status. For the system to determine whether the unit has been moving between the home and the office, it is necessary to create the corresponding geofences in the monitoring system and indicate them for home and office in the application settings. Therefore, the system can recognize whether the initial and final points of the route are located in the indicated geofences or not. If the initial or the final points of the route are not located in the indicated geofences, the trip status is determined by the Private mode sensor.
If a trip status has not been determined by the sensor or there are no indicated geofences in the settings, then the trip gets the Business status by default. In that case, to confirm the status of the trip or trips, click on the Apply button in the upper-right corner.
You can also set a common status for all the trips on the indicated interval. To do this, choose the required variant from the dropdown list (business, personal o no status) and click Apply.
You can also edit a trip status by choosing the appropriate variant from the dropdown list opposite to its name. Along with the standard trip statuses (Business, Personal, Home-office-home), you can also use custom ones. Click on the status field opposite to the trip name, enter the status from the keyboard and click on the save icon  to apply the changes. You can also edit all the necessary statuses and click on the Apply button to save all the changes.
