Tacho View
This functionality is considered outdated and not recommended for use.
Tacho View is a solution developed to analyze data received from tachograph files. The analysis is made on the basis of the following criteria: driving, work, availability, rest. Driver activity is visually displayed on the timeline in order to facilitate the analysis. Moreover, you can find detailed information in reports which you can download in the XLS format or print.
