Actions with desktops
When you open the solution for the first time, only one desktop is available, and one navigation button in the top bar. However, you can create up to 10 separate desktops to monitor counters/sensors values. To do this, click on the Add desktop button in the top bar. You can enter a name for every desktop. To do this, open a required desktop, click on its button again and enter a name. To save the name, press Enter on the keyboard or click on any place of the interface. To open a desktop, click on its name. You can also open the desktop using hotkeys (numbers from 1 to 9) or their combinations ( press the right/left arrow, holding Ctrl). You can copy or delete any desktop using the icon located next to the Add desktop button.
Desktop background is white by default. Using the buttons in the top bar, you can change the background colour, set any picture (indicating its URL address), or use the Gurtam Maps map.
