Driving quality assessment parameters
As mentioned earlier, there is a set of parameters for a driving quality assessment: speeding, acceleration, braking, acceleration while cornering, reckless driving, idling and custom parameters depending on the selected sensors. You should select these parameters on the Eco driving tab in the unit properties. Moreover, you should indicate the number of penalty points for every parameter, which is assessed for a certain violation. The penalty points are converted into the 10-point assessment system. The following algorithm is used:
Penalty Rank
0 10,0
0–17 9,0–10,0
17–38 8,0–9,0
38–67 7,0–8,0
67–107 6,0–7,0
107–167 5,0–6,0
167–267 4,0–5,0
267–467 3,0–4,0
467–1067 2,0–3,0
more than 1067 1,0–2,0
You can find a more detailed description of the algorithm in the documentation of the monitoring system.
