Exporting data
This option allows you to export unit or unit group data to a file. There are two supported formats: XLS and PDF. To export the unit group data in the XLS or PDF format, click on the  or  respectively in the header of the table to the right of the button . If you can’t see the icons, scroll to the right.
To get a file with the data about one unit, point to the required unit and click on the button that appears at the end of the line. You can also export data from the tab with detailed information about the unit. To do this, click on the export button in the upper-right corner of the workplace.
