Video monitoring: configuration and usage
Video monitoring is an important tool for ensuring security and control in various fields of activity. With technological advancements, the capabilities of video monitoring have expanded significantly, and today they include not only video recording and storage but also live streaming, real-time video stream analysis, as well as integration with various management and monitoring systems.
In this article, we will take a detailed look at how to configure and use video monitoring features in Wialon. You will also learn about its main features: live streaming, video file recording and storage, and automatic video saving via notifications.
Initial device configuration
Wialon supports a wide range of devices for video monitoring, and this list is regularly updated. You can see the full list of supported hardware on our website in the corresponding Hardware section. The search filters allow you to pick a device with the required functionality.
Some devices only need to be configured to send data to the Wialon server and port specified in the unit properties on the General tab. However, other devices may require additional configuration in the Device configuration block (under the wrench icon to the right of the Device type field).
You can verify that the unit has a consistent TCP/UDP connection in the Monitoring tab by using the Connection status option. It is recommended to set 0 minutes in the Connection status field so that the state is determined only by the presence of a TCP/UDP connection.
Video monitoring configuration
After the devices have been configured and have a consistent connection to the server, you can proceed to the video monitoring features configuration in Wialon. It consists of the following consequential steps:
  1. Activation of the Video monitoring and Units:Commands services in the account properties where the unit was created for future tracking, as well as in all parent accounts in the hierarchy. These services must also be enabled for user accounts utilizing the video monitoring functionality.
  2. Providing the required access rights for the users who plan to work with video monitoring (viewing live streaming, requesting and saving video recordings, using notifications with the action type Save a video as a file) concerning units:
    • View object and its basic properties;
    • View detailed object properties;
    • View connectivity settings;
    • View commands;
    • Create, edit, and delete commands;
    • Send commands;
    • View video — grants basic access to the video player, live stream, and playback;
    • Manage video (optional) — grants access to deleting saved video files, viewing and modifying the Video tab of the unit properties, purchasing traffic packages, and performing other video-related management tasks in CMS Manager.
  3. Adding units to billing on the Video tab in the CMS Manager.
    This tab is available only to users with dealer rights with the Video monitoring service enabled.
    For more details on billing and purchasing traffic packages, see the corresponding article. Key points are listed below:
    • Once you add a unit to the billing list, one traffic package (1024 MB) is automatically purchased for it.
    • On the first day of each month, any unused traffic is lost, and a new package (1024 MB) is automatically purchased.
    • The automatic purchase of traffic packages option is available. When enabled, a new traffic package is automatically purchased for the unit once its current traffic is used up.
  4. Configuring cameras in the Video tab of the unit properties.
    The tab is available in the properties only for the units added to video billing in the CMS Manager.
    Select the required cameras.
    Then, specify their names, making it easier and faster to tell them apart.
    You can also enable the Automatic saving option for the chosen cameras. This feature allows you to automatically save a video when a notification with the Save a video as a file action is triggered. If you do not use such notifications, the status of this option will have no effect whatsoever.
    Some devices support recording and sending a video when certain conditions are met (for example, if the driver starts a phone call while driving). If Wialon supports receiving such videos and you want to get them, enable the Receive files of events detected by device option in the upper right corner of the tab. Enabling this option is considered mandatory for Teltonika DualCam and Teltonika DashCam, as well as some other cameras.
    Receiving such videos may result in a significant increase in traffic consumption.
Q&A
What if the playback of recordings doesn't work
Make sure that the time zone in the unit’s settings matches the device’s time zone. In Wialon, the unit time zone is set in the general unit properties in the Device configuration block (under the wrench icon to the right of the Device type field) in the Time zone in minutes field (although this setting is not available for all device types). To check the device’s time zone, you can send the corresponding command (specified in the device documentation or by the manufacturer) or check the timestamp watermarked on the video.
Please note that some devices only allow requesting recordings from one camera at a time. In such cases, you can hide the rest of the cameras in the interface and request the recording from only one camera at a time.
How to fix interrupted playback of requested recordings?
If the live stream works but the video in the Playback section gets interrupted (starts and stops), this may be due to insufficient connection speed. You can try lowering the recording quality or request playback from one camera at a time.
How to synchronize the time in the system with the timestamp watermarked on the video?
It is normal if the user and the device are in different time zones, so in most cases, no action is needed. However, this may cause an issue when requesting and saving recordings if the following conditions are not met:
  • The device time zone must match the time zone where the unit is located.
  • The device time zone must match the unit time zone in the general unit properties in the Device configuration block (under the wrench icon to the right of the Device type field) in the Time zone in minutes field (although this setting is not available for all device types)
    To check the device time zone, you can send the corresponding command (see the device documentation or contact the manufacturer).
What if video does not work in Wialon for Android/iOS?
Make sure that the device uses the H.264 codec.
How to configure video monitoring in Wialon Local?
In version 2504 and the older ones, video monitoring is not available in the form described in this article. To view videos and live streams in Wialon Local, you need to install a special application. Also, please note that the video monitoring functionality in Wialon Local works only for Howen, Streamax, and CMSV6 Gateway devices.
Displaying the results
Video tab
This tab is the main workspace for video monitoring. Its logic of operation is described in detail in the user guide.
The tab contains three sections:
  • Live stream for viewing video streams in real time and tracking units on the map.
  • Playback for requesting and saving video fragments for the past period.
  • Files for viewing and deleting saved pieces of footage.
Similar functionality is also available in Wialon for Android/iOS.
Notifications
Using a notification with the Save a video as a file action type, you can automatically save a video fragment recorded by the unit’s cameras when the notification is triggered.
The saved file will be available in the Files section of the Video tab, as well as in messages and reports.
Reports
You can view saved video recordings in reports using the Video table.
Recordings are also available in the Video column in some tables (for example, Trips, Geofences, Eco Driving, Violations, etc.).
Other
  • On the Monitoring tab, you can open a live stream in a minimap by clicking the corresponding option icon .
  • You can display the saved video recordings on the unit’s track if the corresponding marker is enabled .
  • When requesting messages, video recordings saved with the help of the notifications with the Save a video as a file action type can be found in the Video column.
Nikita Sologub
Nikita Sologub Customer Service Engineer
