Resource/Account ACL
If a user gets access to a resource, they can view and use its contents (geofences, jobs, notifications, drivers, report templates, and so on) for tracking purposes as well as create such objects in this resource in the main interface of Wialon.
If a resource is also an account, the advanced access rights (such as adding payments, restricting services and determining their cost, and so on) are applied to it. Such operations are possible only in the CMS Manager interface.
Standard rights
The standard rights that can be applied to resources/accounts are described below.
View object and its basic properties
Allows you to see whether system objects such as units, users, unit groups belong to this account. It is usually written on the first tab of their properties dialog.
View detailed object properties
Applicable to accounts only. The second and third sections of the account properties dialog become visible as well as the Services, Restrictions, and Advanced tabs. If the end user is given this right to their account, the Account tab will appear in the user settings which allows viewing the current balance of the account, information on used and available services, etc.
Delete object
Allows you to delete the resource with all its contents. However, to delete an account, you should additionally check the Manage account box.
Request reports and messages
In the case of resources, this right allows the user to generate the Log table and see how different users created, edited, and deleted the contents of the resource (the Manage object log right is required). It also allows the user to generate reports on drivers and trailers, as well as driver and trailer groups if they belong to this resource. In the case of accounts, this right gives permission to see the Statistics tab (the history of payments and withdrawals) but only if you check the View detailed object properties box, too. A similar section appears on the Account tab of the user properties dialog.
Edit not mentioned properties
Allows you to edit the FTP-server settings on the Advanced tab of the account.
Standard access rights (Manage access to this object, Rename object, View custom fields, Edit custom fields, View admin fields, Edit admin fields, Manage object log, View and download files, Upload and delete files) work for resources/accounts as described above.
Such checkboxes as Change icon and Edit ACL-propagated objects do not affect resources or accounts at all.
Special rights
The table below displays special rights which can be applied to resources/accounts.
Resource ACL
View geofences
Allows you to view the geofences created within a resource.
Create, edit, and delete geofences
Allows you to edit and delete the geofences of this resource, as well as create new ones.
View jobs
Allows you to view jobs created within a resource.
Create, edit, and delete jobs
Allows you to edit and delete the jobs of this resource, as well as create new ones.
View notifications
Allows you to view notifications created within a resource.
Create, edit, and delete notifications
Allows you to edit and delete the notifications of this resource, as well as create new ones.
View drivers
Allows you to view drivers and driver groups of a resource. In addition, it allows you to view the automatic assignment list of the drivers.
Create, edit, and delete drivers
Allows you to edit and delete the drivers and driver groups of this resource, as well as create new ones. Moreover, it allows you to create and edit the automatic assignment list of drivers.
View passengers
Allows you to view passengers created within a resource. In addition, it allows you to view the automatic assignment list of the passengers.
Create, edit, and delete passengers
Allows you to edit and delete the passengers of this resource, as well as create new ones. Additionally, it allows you to create and edit the automatic assignment list of the passengers.
View trailers
Allows you to view trailers and trailer groups created within the resource. Moreover, it allows you to view the automatic assignment list of the trailers.
Create, edit, and delete trailers
Allows you to edit and delete the trailers and trailer groups of this resource, as well as create new ones. In addition, it allows you to create and edit the automatic assignment list of the trailers.
View report templates
Allows you to view report templates created within a resource.
Create, edit, and delete report templates
Allows you to edit and delete the report templates of this resource, as well as create new ones.
Manage account
For accounts only. Combined with the Delete object checkbox, it allows to completely delete the account from the system, together with the resource and its contents, account creator, and all objects created by this user. In combination with the View detailed object properties checkbox, it gives permission to control the billing plan and payment (the General tab), number and cost of services (the Services tab), and some other parameters (the Restrictions tab).
View orders
Allows you to view orders created within a resource.
Create, edit, and delete orders
Allows you to edit and delete orders of this resource, as well as create new ones.
In the main Wialon interface, only manipulations with inner resource contents are possible (i. e. geofences, notifications, report templates, drivers, etc.), including the permission to see the log of content changes. The account-related activities (such as payment control, tarification, etc.) can be performed only in the CMS Manager interface.
Download PDF file
Download Word document
See also
