Session Management
The Session Management window shows the list of applications that have access to your account and the list of devices that can receive mobile notifications from Wialon. The lists are formed automatically after logging in to the application.
To open the window, click on the username in the upper-right corner and select the Session Management item.
The window consists of two tabs: Authorized applications and Mobile notifications.
This tab shows the list of applications that have access to your account data. If you log in to the application from a mobile device, the device name is displayed instead of the application name.
The line of each application shows the following information:
  • application name (mobile device name);
  • token creation date and time;
  • access rights of the application to the account;
  • link to copy the token.
To copy a token, click Copy in the required line. The token is copied to the clipboard.
To prevent the application from accessing the account data, remove it from the list by clicking on the icon   at the end of the line. To save the changes, click OK.
This tab shows the list of applications that can send notifications to your mobile devices.
To prevent the application from sending mobile notifications, remove it from the list by clicking on the icon  at the end of the line. To save the changes, click OK.
