Export to KML and KMZ
This function allows you to copy geofences from all available resources to a KML or KMZ file.
To export geofences, follow these steps:
In the user menu, select the Import/Export item and click Export to KML/KMZ.
Customize the filter by the geofence type or by the resource to which it belongs to find the required geofences.
Select the geofences in the list.
Enter the file name.
Use the Compress file option to save the geofences in the compressed KMZ format.
Click OK to save the file to disk.
