Drivers
To access the Drivers tab, the Drivers service should be enabled in the account properties. To work with drivers and their groups, the user should have the Create, edit, and delete drivers access right to the resource of the account.
To work with drivers, click on the Drivers tab in the top panel or select a same-name item in the main menu. To work with groups of drivers, switch to the Groups mode.
On this tab, you can create drivers to use them later when monitoring units, executing reports, and configuring notifications (see more). Here you can also perform the following actions with drivers: assigning and separating from units, managing the assignment history, sending SMS messages, editing properties, copying, and deleting.
Download PDF file
Download Word document
See also
