Parameter Conversion
Conversion can only be applied to the parameters received directly from the device. The ways of applying this operation are described below.
Bitwise parameter control
Bitwise parameter control allows you to control a specific bit of a parameter. This operation is used if the device shows different data in one parameter: the first bit can correspond to the state of the alarm (on/off), the second to the state of the driver door (open/closed), the third to the state of the headlights, and so on.
To control, for example, the third bit of the parameter param199, type a colon and the bit number after its name:
Copied!
param199:3
In this way, you can create several sensors on the basis of one parameter to control different bits.
Conversion of text parameters
If a sensor has an expression parameter which contains a text parameter, then the text value is converted to a 53-bit integer. By default, this value is considered decimal. If the value belongs to another numeral system, enter a colon after the text parameter and specify this numeral system. Thus, the value will be converted to the decimal system automatically. For example, if the parameter text_param sends the value 100, then
Copied!
text_param = 100
text_param:10 = 100
text_param:16 = 256
text_param:2 = 4
Determination of the day number in a year
You can convert the UNIX time of the message to the day number relative to January 1st. To do this, create a custom sensor with the parameter time:d.
For example, for 11:00:00 (UTC) March 28, 2017, the UNIX time is 1490698800. Therefore,
Copied!
time = 1490698800
time:d = 87
