Route ACL
Route access rights are described below.
View object and its basic properties
Activating this right allows you to see a route on the Routes tab.
Manage access to this object
Allows you to transfer the right to the routes to other users. Moreover, this right allows you to see the route not only on the Routes tab but also on the map. The user can edit the route (add, delete checkpoints, and change their radius), add schedules, show a list of rides for the route, and copy the route.
Delete object
Allows you to delete a route.
Rename object
Allows you to rename a route.
Request reports and messages
Allows you to receive reports containing data about the available route.
