General Properties
To open the billing plan properties, click on its name in the table.
On the General tab, you can specify the basic settings of the billing plan related to the blocking of accounts, data storage and so on. Some of these settings you can specify manually for each separate account.
The table below shows the properties available on this tab.
PropertyDescription
NameThe name of the billing plan (4–50 characters). See more about the input rules here.
Parent planThe parent (recursive) billing plan (optional). If it is assigned, the current billing plan inherits all its properties. These properties can be changed later but considering that the capabilities of a filial billing plan cannot exceed the capabilities of the parent one.
Block by balanceThe balance state (amount of money) at which the users of accounts with this billing plan cannot log in to the system.
Limit by balanceThe balance state at which some services and access to CMS Manager should be disabled for accounts with this billing plan. This option works similar to the same-name option in the account properties.
Block by days
The number of remaining days at which access to the system is blocked. Five days before the blocking, the user begins to receive a warning message when logging in to the system, which contains the number of days before the account is blocked.
Blocking by days doesn't depend on the balance state. If the values for blocking by days and by balance are specified at the same time, then the account is blocked according to one of these conditions which comes first.
If necessary, you can enable or disable the three options mentioned above. If enabled, they are usually set to 0. You can find and change the balance state (money and days) in the account properties.
Currency formatThe symbol of currency. It is specified before or after %.02f. For example, %.02f$.
History period
The time period during which the unit history (the database with messages from the unit), the user logs and the unit log are stored in the system. You can specify the data storage period in days or months (select in the drop-down list). All messages older than the storage period are deleted from the database automatically. You can also specify this property for each account individually, but its value cannot be greater than the one set in the billing plan.
Map tags
In this field, you can specify the tags of the maps that should be used for the billing plan. The tags should be separated by commas. If the field is empty, it assumes that all default maps will be available.
Tags are indicated in the following way:
  • map name: an indicated map will be available as main one;
  • '+' symbol is indicated before a map name: an indicated map is enabled in addition to the main one;
  • '-' symbol is indicated before a map name: an indicated map is disabled.
DescriptionThe description of the billing plan (optional).
