Engine Hours
The Engine hours report shows how long the unit worked, how much time was in motion, how much fuel was spent for this period. Also, the duration and efficiency of the work of the attachable equipment can be shown.
To generate this report, the unit is supposed to have such sensors as ignition or absolute/relative engine hours sensor. The method of calculating engine hours is set in unit properties on the General tab. On the Advanced tab, you can also set Daily engine hours rate to calculate utilization and productivity.
In the report template, you can specify the mask for the main engine hours sensor that is used in the report (the Engine hours sensor filter). This allows you to separate the engines and create a table for each of them.
There are two options that can be used in the engine hours report. They are timeout (set for a sensor) and maximum interval between messages (set for a unit). Both options are used to cut off invalid intervals when the amount of engine hours is defined. If values for both timeout and maximum interval between messages are indicated, the system will use the property with the minimum value indicated.
The table can include the columns described below.
ColumnDescription
BeginningThe time when the engine hours interval begins.
Initial locationThe location of the unit when the engine or implement starts working.
EndThe time when the engine hours interval ends.
Final locationThe location of the unit when the engine or implement ends working.
Engine hoursThe value of engine hours at the interval. For an accurate engine hours calculation, the equipment should send a valid parameter value of the engine sensor. In case of receiving an invalid value, it is necessary to replace the sensor with validator using the correct value (for example, 0).
Initial engine hoursThe value of the sensor of absolute engine hours at the moment of starting the engine. If there are no sensor readings, the initial value is calculated by the counter of engine hours from the beginning of the report interval to the moment of starting the engine.
Final engine hoursThe value of the sensor of absolute engine hours at the end of the interval.
Total timeThe duration of the interval. If grouping by days is enabled, it shows the time from the beginning of the first engine hours interval to the end of the last interval.
Off-timeThe period of time passed from the end of the previous interval to the beginning of the current one (determined starting from the second interval).
In motionThe interval of time during which the unit moved, that is, the speed value was greater or equal to the one from the Min moving speed field in the trip detector.
IdlingThe time when the unit was standing with the engine on. Note that idling cannot be detected if the equipment does not send messages containing speed value.
MileageThe distance travelled during the operating hours.
Mileage (adjusted)Mileage subject to the coefficient set in the unit properties (the Advanced tab).
Initial mileageThe value of the mileage sensor at the moment of the beginning of the reporting period.
Final mileageThe value of the mileage sensor at the end of the reporting period.
Avg speedThe average speed during the interval of engine operation.
Max speedThe maximum speed during the interval of engine operation.
CounterThe counter sensor value.
Initial counterThe counter value at the beginning of the interval.
Finale counterThe counter value at the end of the interval.
Avg engine revsThe average rate of engine revolutions.
Max engine revsThe maximum rate of engine revolutions.
Avg temperatureThe average temperature value registered for the interval of engine operation.
Min temperatureThe minimum temperature value registered for the interval of engine operation.
Max temperatureThe maximum temperature value registered for the interval of engine operation.
Initial temperatureThe temperature value at the beginning of the engine hours operation.
Final temperatureThe temperature value the end of engine hours operation.
StatusThe status of the unit registered during engine hours operation (if there are several, the first one is displayed).
Cargo weightThe average value of cargo weight during the engine hours interval.
DriverThe name of the driver (if assigned).
TrailerThe name of the trailer (if assigned).
Movement productivityThe percentage ratio of engine hours in the movement to the duration of engine hours.
Engine efficiency durationThe duration of the operation of attached equipment (if there is the engine efficiency sensor).
Engine efficiency idlingThe engine operation time after deduction of efficiency time (total engine hours subtract engine efficiency duration).
UtilizationThe percentage ratio of the duration of engine hours to engine hours rate (engine hours divided by daily engine hours rate indicated in the unit properties in the Advanced tab).
Useful utilizationThe percentage ratio of the duration of engine efficiency to the engine hours rate.
ProductivityThe percentage ratio of the duration of engine efficiency to the duration of engine hours.
ConsumedThe volume of consumed fuel detected by any sort of fuel sensor. If several sensors are available, their values sum up.
Consumed by...The fuel volume detected by a fuel sensor or calculated by math or rates.
Avg consumptionThe average fuel consumption by all available fuel sensors.
Avg consumption by...The average fuel consumption detected by a fuel sensor or calculated by math or rates.
Consumed in motion by...The fuel volume used in engine hours while moving.
Avg consumption in motion by...The average consumption in engine hours while moving.
Consumed in idle run by...The fuel volume used in engine hours during idle running.
Avg consumption in idle run by...The average fuel consumption in idling.
Avg consumption by... in tripsThe average fuel consumption in trips.
Initial fuel levelThe fuel level at the beginning of the interval.
Final fuel levelThe fuel level at the end of the interval.
Max fuel levelThe maximum fuel level during the engine hours interval.
Min fuel levelThe minimum fuel level during the engine hours interval.
PenaltiesThe penalties calculated for the adjusted Eco driving criteria.
RankThe received penalty points converted into a grade using 6 point scoring system.
Avg value of custom sensorThe average value of a custom sensor during the engine hours interval.
Min value of custom sensorThe minimum value of a custom sensor during the engine hours interval.
Max value of custom sensorThe maximum value of a custom sensor during the engine hours interval.
Initial value of custom sensorThe value of a custom sensor at the beginning of the engine hours interval.
Final value of custom sensorThe value of a custom sensor at the end of the engine hours interval.
For the engine hours report, you can apply interval filtration by engine hours sensor, duration, mileage, engine hours, speed range, trips, stops, parkings, sensors, sensors masks, driver, trailer, fuel fillings, fuel thefts, and geofences/units. If the engine hours are counted according to the engine hours sensor, it is possible to filter the intervals not only by the duration of their operation (that is the duration of their on-state), but also by the value of the engine hours sent by the sensor itself.
