Unit ACL
A user can obtain the ability to see a unit on the map, track its state (speed, sensor values, etc.), change its properties, execute commands, generate reports about its activity, use the unit in jobs and notifications, etc.
Standard access rights have been described above. Below is the list of special rights which can be applied specifically to units:
| Unit ACL | |
| View connectivity settings | Allows to view the device type, unique ID, phone number(-s), device access password on the General tab, as well as the filtration parameters of the messages on the Advanced tab. In addition, the device type, phone number(-s), and UID also appear in the unit tooltip and in the extended unit information. If the SMS service is activated, the user can also send text messages to this unit. |
| Edit connectivity settings | Allows to edit the device type, unique ID, phone number(-s), device access password on the General tab, and messages filtration parameters on the Advanced tab. |
| Create, edit, and delete sensors | Sensors and their values are always visible, but this checkbox allows to edit and delete them, as well as create new ones. Additionally, the calculation tables and graphs of the created sensors become available for editing. |
| Edit counters | Allows to change the values of the counters (GPRS traffic, mileage, engine hours) and methods of their operation. |
| Delete messages | Allows to delete data messages and messages about sent commands in the Messages panel. It also allows to delete the records from the log (if the Manage log checkbox is enabled). Works only in combination with Query messages or reports check box. |
| Execute commands | Allows to send commands (e.g. from the Monitoring panel). In addition, when configuring tasks and notifications, this right is checked to display the commands in the list of the available commands. |
| Manage events | Allows to register such events as fuel fillings, maintenance work, custom event, and unit status. A special registrar in the Monitoring panel is used for that. Also this checkbox allows to delete already registered events. If the Manage log checkbox is enabled, a record can be added to the unit log. |
| View service intervals | Allows to view the Service Intervals tab in the unit properties dialog as well as view the maintenance state in the unit tooltip and extended unit information. |
| Create, edit, and delete service intervals | Allows to edit and delete service intervals as well as create new ones. Works only in combination with the previous checkbox. |
| Import messages | Allows to import messages to a unit database. Works only in combination with the Query messages or reports check box. |
| Export messages | Allows to export messages from a unit to a file. Works only in combination with the Query messages or reports check box. |
| View commands | Enables the Commands tab in the unit properties. |
| Create, edit, and delete commands | Allows to create, edit, and delete commands on that tab. Works only in combination with the previous checkbox. |
| Edit trip detector and fuel consumption | Allows to edit such tabs as Trip Detection, Fuel Consumption, Eco Driving, and report parameters on the Advanced tab. Works only in combination with the View detailed item properties check box. |
| Use unit in jobs, notifications, routes, retranslators | Allows to create jobs and notifications for the unit, assign it to routes, and use it in retranslation. |
Some details about standard rights for units:
- View item and its basic properties
 The following information is available in the unit properties dialog: on the General tab — name, creator, account, counters; on the Advanced tab — color schemes for sensors and tracks; on the Sensors tab — the list of sensors; on the Unit Groups tab — the list of groups where the unit belongs (if the groups are accessible). The information about the current state of the unit can be seen in its tooltip and in the extended unit information: the time of the last message, current location, speed, altitude, satellites, values of counters, sensors, and parameters, as well as the presence in geofences and assigned driver. The checkbox allows to see the unit in various lists and panels, monitor its movements on the map in real time (though the tracks cannot be built) and watch its movement along the routes (but it cannot be assigned to the rounds). This checkbox also allows to control unit groups, i.e. add/remove the unit to/from groups which can be done through the properties dialog of the unit group.
- View detailed item properties
 Gives access to the settings used for the reports. The user can see the properties applied to the reports: the Trip Detection and Fuel Consumption tabs, report parameters and messages filtration settings on the Advanced tab. Neither editing these things nor report execution is allowed.
- Edit not mentioned properties
 Allows to edit the color schemes for sensors and tracks on the Advanced tab.
- Query reports or messages
 Allows to view messages for the selected interval (except for the log), query reports (except for the tables Log and Custom Fields which require additional rights), and build tracks.
- Manage item log
 Allows to query the unit log through messages or reports (if the checkbox Query reports or messages is enabled) and make custom records in the log (if the box Manage events is checked).
Other standard access rights (Manage access to this item, Delete item, Rename item, View custom fields, Manage custom fields, View admin fields, Manage admin fields, Change icon, View and download files, Upload and delete files) work as described above. The Edit ACL propagated items check box does not affect units at all.
