Export to KML/KMZ
This option allows you to export geofences from all available resources to a file.
When you export to KML/KMZ, the list of all available geofences (depending on the item type chosen) is displayed. Check the items you want to export and press OK. Optionally, you can enter a file name and compress the file as KMZ. After that, press OK and save the file.
