General Information
The top block displays the general status information about Wialon Local.
The parameters available in the block are described below.
ParameterDescription
Wialon statusThe current state of Wialon Local: running or stopped. The duration of the Running status is displayed in the hours:minutes:seconds format.
Units onlineThe percentage ratio of the number of units online to the total number of the created units. The value in parentheses is displayed in the x/y format, where x is the number of units online and y is the number of all created units.
Users/Sessions
The number of users created in the system and the number of active sessions at the moment.
One user can create multiple sessions.
Wialon DBThe total size of the Wialon database.
MessagesThe total size of all messages in the Wialon database.
PropertiesThe total size of all elements and their properties in the Wialon database.
Synchronization cacheThe size of the cache used to synchronize the main database with the backup server (if the server is configured). The worse the connection, the larger the cache size.
FragmentationThe current level of database fragmentation (expressed as a percentage).
Messages cacheThe size of the message cache on the disk. The more intense the flow of messages from the equipment, the higher the readings.
FilesThe total size of files (icons, pictures, etc.) that are stored in the database.
Transaction cacheCache size used to collect messages. Messages are uploaded to the database every 10 minutes.
