System info
The System info block displays the usage of available memory and the average processor load.
ParameterDescription
RAM usageThe amount of RAM in use. It is shown as a percentage in the x/y format, where x is the amount of memory used and y is its total amount. The process indicator for RAM simultaneously shows the data for the Used (darker color) and Cached values.
HDD usageThe amount of disk space in use. It is shown as a percentage in the x/y format where x is the amount of the used space on the disk and y is its total volume. If the value of the used disk space reaches 90%, the administrator receives an alert (the administrator's email is specified on the System tab). In addition, if the critical level of free space (5 GB) is reached, the service stops automatically to avoid database corruption. In this case, an email is also sent to the administrator.
CPU usageThe data on CPU usage (expressed as a percentage). The total number of cores of the installed processors is shown in parentheses.
Load averageServer load indicator for the last 1/5/15 minutes.
Download PDF file
Download Word document
See also
