Restoring Resources and Unit Properties
In this block, you can enable the function of restoring resource contents and unit properties in the management system in case they are changed or deleted.
Active. If the option is enabled, the Restore contents button becomes available in the resource and account properties.
Storage term, days. In this field, you should indicate the number of days within which the user can restore the data after it has been changed. The maximum allowed value is 90, the recommended value is 15.
