Restoring resources and unit properties
In this section, you can enable the function of restoring resource contents and unit properties in the management system in case they are changed or deleted.
Below are the fields available in the section.
Setting Description
Active If the option is enabled, the Restore contents button becomes available in the resource and account properties. The option is enabled by default.
Storage term, days In this field, you should indicate the number of days within which the user can restore the data after it has been changed. The maximum allowed value is 90, the recommended value is 15.
