Upcoming maintenance
The Upcoming maintenance table contains the list of service works set for a unit and the status of their execution. The table can include the columns described below.
ColumnDescription
Service intervalThe name of the scheduled maintenance work indicated on the Service intervals tab of the unit properties dialog in the Service name field. The work should be repeated throughout a particular interval indicated on the Service intervals tab.
StateThe overall state of the execution of the service work. In other words, it is the remaining or expired interval of mileage, engine hours, and days.
State by mileageThe remaining or expired mileage interval.
State by engine hoursThe interval of the remaining or expired engine hours.
State by daysThe interval of the remaining or expired days.
DescriptionThe information taken from the corresponding field on the Service intervals tab.
FrequencyThe interval (mileage, engine hours, or days) that shows how often vehicle maintenance should be performed.
Moreover, the individual parameters of grouping (without any connection to the time intervals) are used in the Upcoming maintenance table. The data can be grouped on the basis of the state (planned/expired maintenance), service interval, or unit (for reports on unit groups).
Questions and answers
Reports show incorrect mileage. What should I do?
Possible explanations and actions:
1. Outliers of data.
To detect such outliers, build a track of unit movement for the appropriate period. Outliers of data will be seen on the track as dashed lines.
Ways to overcome outliers:
  • Enable filtering of unit positional information in messages (on the Advanced tab of unit properties). This will not affect old messages but applied to new ones.
  • To correct data in reports, change settings of trip detection, in particular, reduce Maximum interval between messages and increase Minimum satellites.
2. Incorrect settings or operation of the mileage counter.
  • Check the mileage counter settings on the General tab of unit properties.
