Upgrading Wialon Local
Upgrading (updating) the server system is required for the proper functioning of Wialon Local technologies.
Please update Wialon Local strictly according to the steps in the instructions and comply with the requirements for Debian and Node.js versions (see below).
After the upgrade, it is not possible to revert to a previous version.
Wialon Local versions are upgraded consecutively, that is, one after another. For example, if you want to update Wialon Local from version 1504 to 2404, you should upgrade it to version 1604 first, and then to version 1704. After that, you should perform the following operations successively:
The procedure for updating Wialon Local versions varies because they use different versions of the Debian operating system and Node.js packages.
Wialon Local versions Debian versions Node.js versions
1504, 1604, 1704 8 (Jessie) 0.10.x
1704, 1804, 1904 9 (Stretch) 6.x
1904, 2004, 2104 10 (Buster) 10.x
2104, 2204, 2304 11 (Bullseye) 12.x
2304, 2404, 2504 12 (Bookworm) 18.x
Range of device ports
Due to the increase in the number of supported hardware, it has become necessary to expand the range of open ports on servers with Wialon Local.
To do this, open ports from 20100 to 30000 (the previous standard range of ports is from 20100 to 21999) in the iptables rules following the steps below.
  1. If you use the standard iptables configuration, open the /etc/iptables/rules.v4 file and replace the lines:
    Copied!
    -A INPUT -p udp -m state --state NEW -m udp --dport 20100:21999 -m comment --comment "HW ports" -j ACCEPT
    -A INPUT -p tcp -m state --state NEW -m tcp --dport 20100:21999 -m comment --comment "HW ports" -j ACCEPT
    with the lines:
    Copied!
    -A INPUT -p udp -m state --state NEW -m udp --dport 20100:30000 -m comment --comment "HW ports" -j ACCEPT
    -A INPUT -p tcp -m state --state NEW -m tcp --dport 20100:30000 -m comment --comment "HW ports" -j ACCEPT
    You can do the same with one command:
    Copied!
    sed -i 's/21999/30000/' /etc/iptables/rules.v4
  2. Next, execute:
    Copied!
    iptables-restore < /etc/iptables/rules.v4
