Standard commands
Standard commands are commands reserved in the system. Depending on the unit device and its configuration, some of them may be available for the unit. Below, you can see the full list of standard commands and the parameters which you should specify when creating or sending them.
IconCommand typeSystem nameParameters
Query position (requests the current coordinates of the unit)
query_pos
Send position
send_position
coordinates
Block engine
block_engine
Unblock engine
unblock_engine
Activate output
output_on
output number
Deactivate output
output_off
output number
Download messages
download_msgs
time interval (from-to)
Set data transfer interval (how often the device should send data to the server)
set_report_interval
interval in seconds
Send custom message (see more)
custom_msg
command text
Send message to driver (the drivers' responses are displayed in the Chat with drivers window)
driver_msg
message text
Send route (see more)
send_route
checkpoints
Send waypoints (see more)
send_waypoints
checkpoints
Start/Stop WiaTag (for the WiaTag device type)
wiatag_service
Request configuration
request_configuration
Upload configuration
upload_cfg
path to configuration file
Upload firmware
upload_sw
path to firmware file
Query snapshot
query_photo
Query snapshot from camera
query_photo_cam
camera's number
Query DDD (for tachographs)
query_ddd
If your device supports commands which are not in this list, you can send them using the Send custom message command. To do this, you should know the exact command name specified in the device configuration.
If you use a flespi device, it has its own set of commands with customizable parameters.
