Managing work list
To monitor units, you should add them to the work list. Only the units from the work list can be shown on the map and used in different tasks, such as running reports, assigning drivers and trailers, requesting messages and tracks, searching for the nearest units, etc.
The work list has two display modes:
Each of these lists is independent, and their settings are stored separately. When you switch between them, all the settings that were last applied to this type of list are restored.
The groups and units selected in the list are shown on the map. To select an item, point to its row and check the box to the left of its icon.
To search for the required units in the list, use the dynamic search above it. The search is carried out by unit name, group name, unique ID, device type, phone number, and such profile properties of the unit as VIN, vehicle type, registration plate, brand, model, year, and color.
Unit list
To switch to the unit list mode, click on the icon.
In addition to the search described above, you can perform the following actions in this mode:
  • add units to the work list and delete them from it;
  • sort units by various parameters.
Adding units to the work list
You can add units to the work list manually or enable automatic addition of units. To do this, use the following buttons:
ButtonDescription
Opens a menu for adding units manually. The menu consists of two items:
  • add units or groups;
  • add all available.
To add a certain unit or units to the work list, select the first item and follow the guide below.
To add all the units available to you at the moment, select the second item and confirm your action.
This button is unavailable if the automatic addition of units is enabled (see below).
Activates the automatic addition of available units to the work list. If the button is enabled, as soon as new units become available to you, they are immediately shown in the work list.
When the automatic addition feature is enabled, the Data recency filtering is unavailable.
To use this feature, click on the button and confirm your action. To disable it, click on the button again.
If fewer than 20 units are available to you, this feature is enabled by default when you log in for the first time.
Moreover, there are alternative ways of adding units to the work list:
Units created in the monitoring system or CMS Manager are automatically added to the work list of the monitoring panel of the user-creator (you may need to refresh the page or log in again). If the group view monitoring mode is activated in the work list, the new unit automatically gets in the group it was added to at creation, or to the Units outside groups (if it does not belong to any).
If the filtering on the basis of data recency is used and the created unit does not meet the specified conditions, automatic addition to the list does not happen.
Removing units from the work list
For removing units from the work list, the Clear list option must be enabled in the customizer of monitoring options.
To remove a unit from the work list, point to it and click on the icon   in its row. To clear the whole list, click on the icon  in the header.
Removing units from the work list is unavailable if the automatic addition of units is enabled.
Removing units from the work list doesn’t lead to their deletion from the system. You can add them back to the work list using the ways described above. To delete units from the system, go to the Units tab.
Sorting
By default, the work list is sorted by names arranged in direct alphabetical order. The order can be reversed. To do this, use the switch button or in the header.
Besides, it is possible to sort units by other attributes such as motion state, connection quality, etc. To do this, use the buttons in the header:
  • : driver information;
  • : trailer information;
  • : motion state;
  • : last message time;
  • : online connection state;
  • : sensor state;
  • : battery level of the device (tracker);
  • : media files;
  • : video;
  • : commands.
For instance, to sort units by the motion state, use the button . The list is rearranged in such a way that all the moving units appear at the top of the list, and those that are not moving appear at the bottom. To reverse the motion state order of units, click on the button again.
The presence or absence of certain columns is adjustable in the customizer of monitoring options.
Unit group list
To switch to the unit group list mode, click on the icon .
In this mode, the units from the work list are shown by groups. Next to the group name, you can see the number of units in it. The group tooltip displays the list of the units that belong to this group.
In the list, you can perform the following actions with group:
IconAction
Expand the group to see the units belonging to it and information about them.
Collapse the list of units for the group.
Sort groups by name in direct or reverse alphabetical order.
Opens a menu for adding groups and units manually. Works in the same was as in the unit list.
If you add a unit that doesn’t belong to any group, it gets into the Units outside groups group with the icon . Unlike standard groups, this group doesn’t have the feature of editing properties.
If there are no units in the group, it is not added to the work list using this icon.
Activates the automatic addition of available units to the work list. Works in the same was as in the unit list.
Add the remaining units of the group to the list. This icon is shown at the end of the expanded group list only if some units belonging to the group are not shown in the list. You can see the number of the lacking units in the tooltip of this icon.
Send a command to all the units of the group at once.
View or edit the unit group properties.
Clear the list/Delete the group or the unit from the list. Like in the mode described above, this action doesn’t lead to the deletion of units from the group and from the system.
Window of searching and adding units manually
A special window is used to search for units and add them manually to the work list. To open this window, click on the button   and select Add units or groups.
In the window, all the unit groups (in square brackets) and units available to the user are displayed in alphabetical order.
Adding units
If you want the added object to be shown on the map immediately, enable the Show added units on map option.
You can add a unit or a group with its units to the work list in one of the following ways:
  • double-click on the object in the work list;
  • add all the found (filtered) objects using the icon ;
  • replace the existing work list with all the found (filtered) objects using the icon .
If the added unit belongs to a certain group, then this group is also added to the list but without the rest of its units. If the unit doesn’t belong to any group, then it is automatically added to the Units outside groups group with the icon .
Searching by criteria
If you have a lot of units and groups, you can use filters to search for the required object. Below you can find information about filtering in the window for adding objects.
The following filtering criteria are available:
FilterDescription
Name
Search by the unit or group name.
Creator
Search by the user on whose behalf the unit was created. Specified on the General tab of the unit properties.
Unique ID
Search by the unique unit ID specified on the General tab of the unit properties.
Phone number
Search by the phone number specified on the General tab of the unit properties.
Device type
Search by the device type installed on the unit. Specified on the General tab of the unit properties.
Unit group
Search for units by their belonging to a certain group. After selecting the filter, the list shows only those units that belong to a certain group. If you specify the group name in the search field, the list shows only those units that belong to this group.
Unit
Search for unit groups by the unit name. After selecting the filter, the list shows only those groups that contain certain units. If you specify the unit name in the search field, the list shows only those groups to which this unit belongs.
Custom fields
Search by name or value of custom fields added on the same-name tab of the unit properties.
Profile fields
Search by the characteristics specified on the Profile tab of the unit properties.
Accessors
Search by the name of the user who has access to the units. After selecting the filter, specify the user name or the name mask in the search field so that the list shows all the units to which this user has access.
Geofences
Search by the name of the geofence in which the unit is currently located.
Sensors
Search by the name, type, or parameter of the sensor created in the unit properties.
DriversSearch by the name or code of the driver assigned to the unit.
TrailersSearch by the name or code of the trailer assigned to the unit.
Passengers
Search by the name or code of the passenger assigned to the unit.
The filters can work on several levels:
  • at the first level, you select a filtering criterion and the list shows only those units which have the selected property. For example, if you select the Sensors filter, the list shows only those units for which they are created;
  • at the second level, in the search field next to the filter, you specify one or several keywords (their masks) separated by commas. For example, to find all units with ignition sensors and/or fuel sensors, you can select the Sensors filter and specify *ign*,*fuel*;
  • at the third level, you can add one more filtering criterion by clicking on the icon and search among previously filtered units, etc.
List generation by data recency
The work list on the Monitoring tab can be formed dynamically according to the time when the last message with coordinates from a unit is received. Units are removed and added to the list and map automatically. The work list is updated every 10 seconds.
The function can be enabled in the customizer of monitoring options. Change the Without filtering option to Work list or Work list and map and specify the filtering interval in minutes. Then only those units from which data was received during the specified interval will be displayed on the Monitoring tab. If the Work list and map option is selected, the units are added not only to the work list but also to the map.
Filtering is applied to all the units available to the user. Therefore, the units with recent data are shown in the work list and/or on the map, even if they were not added to the Monitoring tab previously.
When using this function, take the following peculiarities into account:
  • Actions in the work list (searching, adding, and removing units) are impossible if the data recency filtering mode is activated.
  • This function doesn’t work simultaneously with the Unit group list mode.
  • This function is available only when the automatic addition of units to the work list is turned off.
