Charts
The Charts section displays visual information on various characteristics. The time interval is selected in the upper right part of the section.
The table below lists all the charts and the curves available for them.
Chart Curves
Users Users, Sessions
Units Units, Units online
CPU CPU, Load average
Processes Processes
Threads Threads (the total number of all threads in the system), Wialon threads (threads occupied by Wialon), Local threads (threads occupied by the wlocal service), Wialon active threads
RAM Total RAM, Used RAM, Cached RAM, RAM Wialon Local
Space Total space, Used space, DB, Messages, Properties, Files, Messages cache, Logs directory, Tmp directory, Synchronization cache, Transaction cash, Compressed messages (the latter is available if the Database compression option is enabled)
DB fragmentation DB Fragmentation
Message intensity (Message tab) Read messages, Written messages, Messages requests
Total number of messages (Message tab) Total number of messages
Disk speed A curve for each disk where the DB is located
Disk IOPS A curve for each disk where the DB is located
Disk utilization A curve for each disk where the DB is located
Network speed Download speed, Upload speed
Network traffic Downloaded data, Uploaded data
To enable or disable the display of any curve, click on its name above the chart.
The gaps in some sections of the curves indicate that the wlocal service was stopped at the time intervals to which the curves correspond (for the Users/Units charts, it signals that Wialon was stopped).
When you hover the mouse cursor over the point of the chart, tooltips appear.
