General information
The top section displays the general status information about Wialon Local.
The parameters available in the section are described below.
Parameter Description
Wialon status The current state of Wialon Local: running or stopped. The duration of the Running status is displayed in the hours:minutes:seconds format.
Units online The percentage ratio of the number of units online to the total number of the created units. The value in parentheses is displayed in the x/y format, where x is the number of units online and y is the number of all created units.
Users/Sessions The number of users created in the system and the number of active sessions at the moment.
One user can create multiple sessions.
Messages (number) The number of messages for the last minute and total number. The data is displayed according to four parameters: requests (the number of messages requests), read, written, total.
Wialon DB The total size of the Wialon database.
Messages (size) The total size of all messages in the Wialon database.
Compressed messages The total size of compressed messages in the Wialon database.
Properties The total size of all elements and their properties in the Wialon database.
Files The total size of files (icons, pictures, etc.) that are stored in the database.
Fragmentation The current level of database fragmentation (expressed as a percentage).
Messages cache The size of the message cache on the disk. The more intense the flow of messages from the equipment, the higher the readings.
Synchronization cache The size of the cache used to synchronize the main database with the backup server (if the server is configured). The worse the connection, the larger the cache size.
Transaction cache Cache size used to collect messages. Messages are uploaded to the database every 10 minutes.
