Connection problems
The Connection problems table lists the time periods when the system did not receive data from the unit. The parameters for this table are adjusted on the Advanced tab of the unit properties where you set Maximum interval between messages.
Below is the information which can be presented in the Connection problems table.
Column Description
Beginning The date and time when connection loss happened.
End The date and time when the connection was recovered.
Duration The time interval of connection loss.
Location The address where the unit was right before the loss of connection.
Count The number of connection gaps detected in a certain time interval (it is advisable when grouping rows by days/weeks/months or for reports about groups of units).
Driver The name of the driver (if available).
Trailer The name of the trailer (if it was assigned).
Notes An empty column for your custom comments.
Video Video files received from the unit.
Image The images received from the unit. Viewing images in reports and the functions available while doing this are described here.
Additional filtering by driver, trailer, and geofences/units can be applied to the Connection problems table.
Questions and answers
