Maintenance
The Service Intervals table contains the list of the service works performed during the indicated period and registered by the user for the selected unit.
The Maintenance table can include the columns described below.
ColumnDescription
Service timeThe date and time indicated at the time of registration.
Registration timeThe date and time when the event was registered.
Kind of workThe information taken from the Kind of work field.
CommentThe information taken from the Description field.
LocationThe location indicated at registration.
DurationThe duration of technical work.
CostThe cost of service.
MileageThe value of the mileage counter at the time of maintenance.
Engine hoursThe value of the engine hours counter at the time of maintenance.
CountThe number of services.
Questions and answers
Reports show incorrect mileage. What should I do?
Possible explanations and actions:
1. Outliers of data.
To detect such outliers, build a track of unit movement for the appropriate period. Outliers of data will be seen on the track as dashed lines.
Ways to overcome outliers:
  • Enable filtering of unit positional information in messages (on the Advanced tab of unit properties). This will not affect old messages but applied to new ones.
  • To correct data in reports, change settings of trip detection, in particular, reduce Maximum interval between messages and increase Minimum satellites.
2. Incorrect settings or operation of the mileage counter.
  • Check the mileage counter settings on the General tab of unit properties.
