Account
The Account tab of the user settings contains the General and Statistics sections. To switch between them, use the buttons at the top of the tab.
To access the tab, the following access rights to the account are required:
  • View object and its basic properties;
  • View detailed object properties;
  • Request reports and messages.
If you don’t have the last right, you can access only the General section.
General
The General section displays the name of the billing plan, current balance, and the table with the list of available services. If the Block by days option is enabled for the account, this section also shows the number of days left.
The table consists of four columns.
Column
Description
Service
The type of service.
In use
The number of items used as part of the service.
Limit
The maximum number of items allowed by the service. A zero value means that the service is unavailable. If a dash is shown, there are no restrictions.
Reset
The frequency with which you can use the number of items specified in the limit (hourly, daily, weekly, monthly).
Statistics
In the Statistics section, you can get information about service charges for the period of up to 60 days. To do this, select the required time interval and click Show.
