Logs
To work with the Logs tab, you should have the Request reports and messages access right.
This tab contains a table which shows how many times the user has logged in or out of the system. To request data for a specific period, select it in the calendar and click Show.
Each line shows the following information about logging in or out of the system:
- date;
- time;
- action type;
- host (IP address of the device) from which the user logged in/out;
- service to which the user logged in/out.
If the user logged in using the web interface, the web/ prefix is added to the service name.
In addition to using the log, you can execute advanced reports on users in the monitoring system.
See more information about working with users in the monitoring system.
