Standard commands
Standard commands are commands reserved in the system. Depending on the unit device and its configuration, some of them may be available for the unit. Below, you can see the full list of standard commands and the parameters which you should specify when creating or sending them.
Icon Command type System name Parameters
Query position (requests the current coordinates of the unit) query_pos —
Send position send_position coordinates
Block engine block_engine —
Unblock engine unblock_engine —
Activate output output_on output number
Deactivate output output_off output number
Download messages download_msgs time interval (from-to)
Set data transfer interval (how often the device should send data to the server) set_report_interval interval in seconds
Send custom message (see more) custom_msg command text
Send message to driver (the drivers’ responses are displayed in the Chat with drivers window) driver_msg message text
Send route (see more) send_route checkpoints
Send waypoints (see more) send_waypoints checkpoints
Start/Stop WiaTag (for the WiaTag device type) wiatag_service —
Request configuration request_configuration —
Upload configuration upload_cfg path to configuration file
Upload firmware upload_sw path to firmware file
Query snapshot query_photo —
Query snapshot from camera query_photo_cam camera’s number
Query DDD (for tachographs)
This method of downloading driver activity data is considered outdated. The recommended and supported method is downloading via flespi. See the How to configure sending tachograph data to Wialon using flespi guide.
query_ddd —
If your device supports commands which are not in this list, you can send them using the Send custom message command. To do this, you should know the exact command name specified in the device configuration.
If you use a flespi device, it has its own set of commands with customizable parameters.
