Notifications
The Notifications tab is available only to the top user and users that are creators of accounts with dealer rights. To work with the tab, you should have the View notifications access right to resources.
Here you can configure the reception of online notifications so that they are sent only from certain resources, not from all the available ones. You can also select the required notification types for each resource.
To change the list of notification types that should come from a resource, do the following:
  1. In the Resources list, select the required resource. For a quick search, use the dynamic filter above the list. To select several resources at once, click on them while holding down the Ctrl key. You can also use special shortcuts.
  2. In the Notification types list, select the ones you want to receive. The number of the notification types selected for the resource is shown opposite its name, and the tooltip to this number shows the list of the selected types. When several resources are chosen, the notification types that are selected only for some of them are marked with a black square.
  3. Click ОК.
