Monitoring system metrics with Grafana
Wialon Local exposes internal system metrics in Prometheus format. You can use Prometheus to collect these metrics and Grafana to visualize them using a preconfigured dashboard template. This guide describes how to enable metrics collection, set up Prometheus and Grafana, and import the Wialon Local dashboard template.
Prerequisites
Before you begin, make sure you have:
  • A running Wialon Local instance.
  • Prometheus installed (or ready to install).
  • Grafana installed (or ready to install).
Step 1. Enable metrics collection
To enable the collection of system metrics:
  1. In the administration system, navigate to System and locate the Settings section.
  2. Select the Enable metrics service checkbox (the last option in the section).
  3. Click Save.
  4. Restart the service when prompted.
After the restart, Wialon Local exposes system metrics in Prometheus format at the following default endpoint:
http://<server-address>/wialon_metrics
where <server-address> is the IP address or domain name of your Wialon Local server.
You can verify that metrics are available by opening this URL in a browser or with curl:
Copied!
curl http://<server-address>/wialon_metrics
Step 2. Install and configure Prometheus
Install and configure Prometheus on the server you’ve designated for monitoring (a separate server is recommended).
  1. Download and install Prometheus.
  2. In the prometheus.yml configuration file, add the following scrape job to collect metrics from Wialon Local:
    Copied!
    scrape_configs:
      - job_name: "adf"
        metrics_path: /wialon_metrics
        static_configs:
          - targets: ["<wialon-local-address>"]
    Replace <wialon-local-address> with the IP address or domain name of your Wialon Local server (for example, 192.168.1.100 or wialon.yourcompany.com). Since the endpoint is proxied through nginx on the standard HTTP port, you don’t need to specify a port number.
    See Prometheus documentation for additional information.
  3. Start Prometheus with the configuration file:
    Copied!
    ./prometheus --config.file=prometheus.yml
  4. Verify that Prometheus is scraping metrics by opening the Prometheus web interface (by default, http://localhost:9090) and checking Status → Targets. The adf target should appear with the UP state.
Step 3. Install Grafana and add the data source
Install Grafana on the same server where Prometheus is running.
  1. Download and install Grafana.
  2. Open the Grafana web interface (by default, http://localhost:3000).
  3. Add Prometheus as a data source:
    • Navigate to Connections → Data sources.
    • Click Add data source and select Prometheus.
    • In the Prometheus server URL field, enter the address of your Prometheus instance (for example, http://localhost:9090).
    • Click Save & test to verify the connection.
See Grafana documentation for additional information.
Step 4. Import the dashboard
A preconfigured Grafana dashboard template is available as a JSON file. To import it:
  1. Download the dashboard JSON template using this link: local-dashboard-template.json .
  2. In Grafana, navigate to Dashboards → New → Import.
  3. Click Upload JSON file and select the dashboard template file.
  4. Select the Prometheus data source you configured in the previous step.
  5. Click Import.
The dashboard displays panels for all key Wialon Local system metrics, including service status, database operations, memory and CPU usage, active sessions, reports, notifications, and more.
Available metrics
The table below lists all system metrics exposed by Wialon Local. For information on metric types, see Metric types.
Service and process metrics
Metric Type Description
adf_process_start_time Gauge Start time of the Wialon Local service (Unix timestamp in seconds).
adf_process_pid Gauge Process ID (PID) of the running Wialon Local service.
adf_service_status Gauge Service status: 1 — running, 0 — stopped.
adf_process_cpu_time_seconds Gauge CPU time spent on process execution (kernel and user mode).
adf_process_mem_pages_in_mem Gauge Number of process pages in physical memory.
adf_process_mem_vmem_used Gauge Amount of virtual memory used by the process (in bytes).
adf_mem_appmem_used Gauge Number of bytes used by application memory.
adf_mem_vmem_used Gauge Number of bytes used as virtual memory (excluding metadata).
Database and storage metrics
adf_storage_msgs_rw_count Counter Total number of messages written to or read from the database.
adf_storage_critical_errors Counter Total number of critical errors returned by storage operations.
adf_sync_server_msgs_flushed_to_fs Counter Number of messages flushed to the file system for a backup server. When the synchronization server is unavailable, messages are temporarily stored on disk and flushed after the server becomes available.
Thread pool and event queue metrics
adf_threads_pool_active Gauge Number of active threads in the global thread pool.
adf_threads_pool_max Gauge Maximum size of the global thread pool. Configured via the ADF_MAX_THREADS_COUNT environment variable (default: 50).
adf_events_queue_size Gauge Number of events in the execution queue. Most events in the system (commands, registered messages, and others) pass through this queue. A minimal queue size indicates fast processing. A growing queue indicates degraded performance.
Script execution metrics
adf_script_code_executions Counter Total number of script executions over a 10-minute window. Most external events (for example, API requests) are processed via scripts. This metric can serve as an indicator of system load.
adf_script_long_exec_number Gauge Number of scripts with execution time exceeding the threshold. The threshold is configured via the ADF_SCRIPT_LONG_EXEC_DETECTION_TIME environment variable (default: 600 seconds).
Web and session metrics
adf_web_ajax_requests_duration_milliseconds Counter Total duration of processed AJAX requests (in milliseconds).
adf_web_active_sessions Gauge Number of active web sessions.
Reports and notifications metrics
adf_reports_count Counter Total number of processed reports.
adf_reports_duration_milliseconds Counter Total duration of processed reports (in milliseconds).
adf_notifications_count Counter Total number of processed notification actions.
adf_notifications_duration_milliseconds Counter Total duration of processed notification actions (in milliseconds).
Unit and hardware metrics
adf_unit_to_tcp_conn_bindings Counter Total number of unit-to-TCP connection bindings. Units that send data establish connection bindings.
adf_unit_to_udp_conn_bindings Counter Total number of unit-to-UDP connection bindings. Units that send data establish connection bindings.
adf_unit_commands_executions Counter Total number of unit command executions.
adf_retranslator_msgs_sent Counter Total number of messages sent by the retranslator service.
Jobs metrics
adf_jobs_completed Counter Total number of completed jobs.
Metric types
Wialon Local metrics use two Prometheus metric types:
  • Gauge: Represents a value that can go up or down (for example, the number of active sessions or memory usage). Gauges reflect the current state at a point in time.
  • Counter: Represents a cumulative value that only increases (for example, the total number of processed reports). Counters reset to zero when the service restarts.
Troubleshooting
Prometheus target shows DOWN status
Check network connectivity between the server running Prometheus and the Wialon Local server. Make sure the metrics_path in prometheus.yml is set to /wialon_metrics and the targets value contains the correct Wialon Local server address. Verify that the Wialon Local server’s HTTP port (default: 80 or 443) isn’t blocked by a firewall.
Grafana dashboard shows "No data"
Verify that the Prometheus data source is correctly configured in Grafana (Connections → Data sources → Prometheus). Check that the Prometheus instance is running and that the adf target has the UP state in Prometheus (Status → Targets). Make sure you selected the correct data source when importing the dashboard.
Events queue size is growing continuously
A continuously growing adf_events_queue_size indicates that the system can’t process events fast enough. Check CPU and memory usage on the server. Review the server hardware against the technical specifications. Contact technical support if the issue persists.
