Using Trailers
Apart from the Trailers tab, you can see trailers on the map on other tabs, in a separate column of the monitoring list and in the additional information about the unit. You can also use trailers in reports and notifications.
Trailers in reports
You can use trailers in the following reports:
Report type Usage method
Reports on units and unit groups In such tables as Geofences, Trips, Parkings, Stops and so on, the Trailer column is available. It shows whether a trailer was assigned to the unit within a certain interval.
Reports on trailers and trailer groups As part of the Advanced reports module, you can generate such reports on trailers and trailer groups as Assignments and Custom fields.
Trailers in notifications
To monitor the assignment and separation of trailers in real time, you can create a notification of the Trailer type. Besides, for any type of notifications, you can select the Separate trailer action. For example, a notification of the Geofence type with the Separate trailer action may trigger the automatic separation of a trailer when the unit enters the garage or final destination, and so on.
