Transferring Unit Properties
Almost any unit properties can be imported and exported.
General properties. Unit name, device type, phone number(s), unique ID(s), device access password (from the General tab).
Icon. Icon of the unit and the state of the Rotate icon checkbox.
Device configuration. Device configuration parameters (from the General tab).
Counters. The current values of counters and their calculation parameters (from the General tab).
Report properties. Parameters used in reports, as well as speeding and driver activity parameters from the Advanced tab.
Advanced properties. Color parameters and messages filtration parameters from the Advanced tab.
Sensors. Contents of the Sensors tab.
Custom fields. Contents of the Custom fields tab.
Admin fields. Available admin fields from the Custom fields tab.
Commands. Contents of the Commands tab.
Eco Driving. Contents of the Eco driving tab.
Profile. Contents of the Profile tab.
Trip detector. Contents of the Trip detector tab.
Fuel consumption. Contents of the Fuel consumption tab.
Service intervals. Contents of the Service intervals tab.
An exception is user access and group membership (if you want to transfer such data, it’s better to use the copy function), as well as information about the creator and account.
Units with the same unique ID within one device type, as well as units or drivers with the same phone numbers, cannot exist in the system. If you attempt to import such fields, their values are emptied, and you can edit them later.
