Transferring Unit Properties
Almost any unit properties can be imported and exported.
PropertyDescription
General propertiesUnit name, device type, phone number(s), unique ID(s), device access password (from the General tab).
Icon
Icon of the unit and the state of the Rotate icon checkbox.
To transfer an individual icon, you must have the View item and its basic properties right towards a unit the icon of which you are going to transfer.
Device configurationDevice configuration parameters (from the General tab).
CountersThe current values of counters and their calculation parameters (from the General tab).
Report propertiesParameters used in reports, as well as speeding and driver activity parameters from the Advanced tab.
Advanced propertiesColor parameters and messages filtration parameters from the Advanced tab.
SensorsContents of the Sensors tab.
Custom fieldsContents of the Custom fields tab.
Admin fieldsAvailable admin fields from the Custom fields tab.
CommandsContents of the Commands tab.
Eco DrivingContents of the Eco driving tab.
ProfileContents of the Profile tab.
Trip detector
Contents of the Trip detector tab.
Fuel consumptionContents of the Fuel consumption tab.
Service intervalsContents of the Service intervals tab.
An exception is user access and group membership (if you want to transfer such data, it’s better to use the copy function), as well as information about the creator and account.
Units with the same unique ID within one device type, as well as units or drivers with the same phone numbers, cannot exist in the system. If you attempt to import such fields, their values are emptied, and you can edit them later.
