Drivers
Wialon system provides a possibility to create and manage the list of drivers working for you. One click of a mouse can assign a driver to a unit, i.e., attach to a vehicle. Then in the reports on this unit, a driver will be indicated. It is particularly useful when several drivers work with the same unit. There is also a possibility to detect drivers automatically with the help of the iButton system. Moreover, created drivers can be formed into groups.
To start working with drivers, select the Drivers item in the top panel, or click on the necessary item in the main menu customizer. Afterwards, select the mode you want to work with (drivers or groups).
