Parkings
Parkings are estimated according to the parameters set in the trip detector when configuring a unit. To get the information as accurate as possible, it is advised that you configure each parameter individually for every piece of equipment.
A parking is an interval of time when the following conditions are met:
  1. Insignificant speed. The speed detected must fall in the range from 0 to the Minimum moving speed. When this speed is reached, the behavior of the unit is regarded as a movement (=trip), if by the time and distance travelled it corresponds to the trip definition (the Minimum trip time and Minimum trip distance parameters). The parking, respectively, ends. However, if the time or distance travelled does not fit the scope of the trip, the parking is prolonged.
  2. Sufficient time interval. This speed must continue for a period of time (and not less than Minimum parking time). If this time is not reached, the behavior of the unit is not regarded as parking, but as a stop.
  3. Insignificant location change. As it has been noted above, parking is also considered an insignificant movement in space, that is, a movement that does not exceed the Minimum trip distance parameter, if it is equal to or greater than the Minimum parking time parameter.
The information which can be presented in this kind of report is described below.
ColumnDescription
BeginningThe time when the parking started.
EndThe time when the parking ended.
DurationThe time interval of a parking.
Total timeThe time from the beginning of the first parking to the end of the last parking.
Off-timeThe time interval from the end of the previous parking to the beginning of the current parking (defined starting from the second parking).
LocationThe address where the unit was stationary. If there was an insignificant movement detected, the initial address is used.
CoordinatesThe coordinates of the unit during the parking (in decimal degrees).
DriverThe name of the driver (if available).
TrailerThe name of the trailer (if one was bound).
CounterThe values of the counter sensor.
Initial counterThe counter value at the beginning of the parking.
Finale counterThe counter value at the end of the parking.
Avg temperatureThe average temperature value registered for the parking interval.
Min temperatureThe minimum temperature value registered for the parking interval.
Max temperatureThe maximum temperature value registered for the parking interval.
Initial temperatureThe temperature value at the beginning of the parking interval.
Final temperatureThe temperature value at the end of the parking interval.
Avg weightThe average weight value registered for the parking interval.
Min weightThe minimum weight value registered for the parking interval.
Max weightThe maximum weight value registered for the parking interval.
Initial weightThe weight value at the beginning of the parking interval.
Final weightThe weight value at the end of the parking interval.
StatusThe status of the unit registered during the current parking interval (if there are several, the first one is displayed).
CountThe number of parkings (useful when grouping rows by years/months/weeks/days/shifts or for the reports on unit groups).
See Data in reports to learn how time (duration) can be formatted.
The interval filtration (by parking duration, sensor state, driver, trailer, fuel fillings/thefts, and geofences/units) can be applied to this table.
The parkings can be displayed on the map. To make use of this feature, select Parking markers in the report template.
Parkings should be distinguished from stops.
