Messages Tracing
The main objective of this report is to facilitate the work with the parameters from the messages. That is why the parameter values are presented not as a single data array but have a particular structure. It means that every parameter is located in its own column.
Along with the parameter values, this report can include other columns described below.
ColumnDescription
TimeThe date and time when the message was sent.
SpeedThe speed of a unit from the received message.
CoordinatesThe coordinates of the unit.
LocationThe location of the unit at the time when the message was sent.
ValueThe value of the parameter sent in a message.
DriverThe name of the driver (if available).
TrailerThe name of the trailer (if one was bound).
NotesAn empty column to add your custom comments after printing or exporting the report.
Note that you can click on a link in such columns as Time, Coordinates and Speed to view the position of a unit on the map.
This table cannot be generated for unit groups.
