Work Area
In the left part of the screen, there is a work area in which various actions with different elements of the system are performed, as well as various requests, are formed.
Depending on the item selected in the top menu, in the work area, you can open one of the tabs described below.
 Dashboard: viewing summary information about the units from the work list.
 Monitoring: tracking units position, state and movements.
Tracks: viewing movement history.
Messages: viewing the messages that come from the units.
Reports: a wide range of tools for analyzing and sorting the data received from a unit.
Geofences: creating, editing, removing geographical areas.
Routes: creating and monitoring the traffic route of a unit according to its schedule.
Drivers: creating drivers and assigning them to units.
Trailers: creating trailers and binding them to units.
Passengers: creating passengers and binding them to units.
Jobs: creating, editing, removing jobs performed on schedule.
Notifications: creating, editing and removing notifications of events.
Users: managing other users.
Units: managing available units.
The main menu can also include two items which are not displayed in the work area. They are:
Tools: tools for calculation distance and area, laying the best routes, searching for the nearest units, etc.
Apps: applications that solve various user’s tasks.
The width of the work area can be changed. To do this, click on its right border and drag it to the required direction, holding the mouse button. Moreover, you can hide the work area by pressing the button located in the lower left corner .
Main menu adjustment and navigation
To adjust the main menu, click on the customizer icon and select the menu items you want to work with. The selected items immediately appear in the top menu.
The open tab is highlighted with a darker background. To navigate through the menu, click on the required name. The contents of the left panel (the work area) change automatically.
All the range of items selected for the main menu is displayed at the top. The names of the tabs are shortened if there is a lack of space. That is why you should select only those items that you actually use.
Alternative means of navigation
If the browser window is small, but there are a lot of panels selected, inscriptions generally become not visible, and menu panels are presented just with icons. In such cases clicking on the icon mostly leads to switching on/off the layer on the map. Therefore, in such cases to switch the panels you should additionally hold the Ctrl key.
Another means of navigation is through the menu settings window. If you click on the name of any item in the settings window, you will be taken to the corresponding tab. In this case, if before it was not displayed in the menu, it appears. Also, do not forget that when you open the tab from the menu settings window, the tab layer is activated automatically.
The same occurs in case of forced transitions between tabs, for example, when requesting a report from the Monitoring tab or during the transition from reports to messages. Even if the requested tab is not displayed in the main menu, the transition is successful. In this case, the corresponding item is added to the menu and the layer becomes active.
Download PDF file
Download Word document
See also
