Geofences
To generate a report on geofences, you should select one or several geofences in the parameters of the table. In this report, you can use both the geofences from the resource in which the report template is created and the geofences from other resources to which the user has the View geofences access right. The resource is selected in the dropdown list above the list of geofences. You can also select the All option for the list to contain the geofences from all the resources to which the user has the necessary access right. The geofences in the list are sorted by name. To quickly find one, use the dynamic filter.
The table can include the columns described below.
ColumnDescription
GeofenceThe name of the geofence.
TypePolygon, line, circle, unit (if units are selected instead of geofences in the report template).
AreaThe total area of the geofence (if the metric system is used, the area will be indicated in hectares).
PerimeterThe perimeter of the geofence. The perimeter for a line is its length (line thickness is not taken into account).
DescriptionThe description of the geofence (taken from the geofence properties).
Time inThe time when the unit entered the geofence.
Time outThe time when the unit left the geofence.
Duration inThe duration of the visit.
Total timeThe time from the beginning of the first visit to the end of the last one.
Parkings durationThe time spent in parkings.
Off-timeThe time between the previous visit and the current one (is defined starting from the second visit of the geofence).
MileageThe mileage inside the zone.
Mileage (adjusted)The mileage subject to the coefficient set in the unit properties (on the Advanced tab).
CounterThe value of the counter sensor.
Initial counterThe counter value when entering the geofence.
Finale counterThe counter value when exiting the geofence.
Avg engine revsThe average rate of engine revolutions.
Max engine revsThe maximum rate of engine revolutions.
Avg temperatureThe average temperature value registered inside the geofence.
Min temperatureThe minimum temperature value registered inside the geofence.
Max temperatureThe maximum temperature value registered inside the geofence.
Initial temperatureThe temperature value when entering the geofence.
Final temperatureThe temperature value when leaving the geofence.
Off-mileageThe mileage travelled from the previous visit.
Off-mileage (adjusted)The mileage travelled from the previous visit subjected to the coefficient.
Avg speedThe average speed with which the unit moved in the geofence.
Max speedThe maximum speed with which the unit moved in the geofence.
DriverThe name of the driver (if available).
TrailerThe name of the trailer (if one was bound).
VisitsThe number of visits (can be helpful either in grouping table data by years/months/weeks/days/shifts or for the reports on unit groups).
ConsumedThe amount of consumed fuel detected by any sort of fuel sensor. If several sensors are available, their values sum up.
Consumed by ImpFCS/AbsFCS/InsFCS/FLS/math/ratesThe volume of consumed fuel detected by a fuel sensor (such as impulse/absolute/instant fuel consumption sensor, fuel level sensor) or calculated by math or rates. More details about fuel in reports can be found here.
Avg consumptionThe average fuel consumption by any sort of fuel sensor. If several sensors are available, their values sum up.
Avg consumption by ImpFCS/AbsFCS/InsFCS/FLS/math/ratesThe average fuel consumption by one of the methods mentioned above.
PenaltiesThe penalties calculated for the adjusted Eco driving criteria.
RankThe penalty points converted to a 6-point rating system.
Avg value of custom sensorThe average value of the custom sensor registered inside the geofence.
Min value of custom sensorThe minimum value of the custom sensor registered inside the geofence.
Max value of custom sensorThe maximum value of the custom sensor registered inside the geofence.
Initial value of custom sensorThe value of the custom sensor registered when the unit entered the geofence.
Final value of custom sensorThe value of the custom sensor registered when the unit left the geofence.
Instead of geofences, you can select units in the report’s template. Additionally, indicate the radius for these units (in meters). In this case, the units are considered as moving geofences, and the activity of the selected unit is analyzed with respect to these moving geofences. The Query reports or messages access is required to these units.
The interval filtration by duration, mileage, engine hours, speed range, trips, stops, parkings, sensors, drivers, trailers, fuel fillings, and thefts can be applied to this table.
Geofences can be displayed on the map. To do this, activate the Render geofences option in the report template.
See related reports: Non-visited geofences, Trips between geofences.
