Charts
The Charts block displays visual information on various characteristics. The time interval is selected in the upper right part of the block.
The table below lists all the charts and the curves available for them.
Chart
Curves
Users
Users, Sessions
Units
Units, Units online
CPU
CPU, Load average
Processes
Processes
Threads
Threads (the total number of all threads in the system), Wialon threads (threads occupied by Wialon), Local threads (threads occupied by the wlocal service), Wialon active threads
RAM
Total RAM, Used RAM, Cached RAM, RAM Wialon Local
Space
Total space, Used space, DB, Messages, Properties, Files, Messages cache, Logs directory, Synchronization cache, Transaction cash, Compressed messages (the latter is available if the Database compression option is enabled)
DB fragmentation
DB Fragmentation
Messages
Read messages, Written messages, Messages requests
Disk speed
A curve for each disk where the DB is located
Disk IOPS
Disk utilization
Network speedDownload speed, Upload speed
Network trafficDownloaded data, Uploaded data
To enable or disable the display of any curve, click on its name above the chart.
The gaps in some sections of the curves indicate that the wlocal service was stopped at the time intervals to which the curves correspond (for the Users/Units charts, it signals that Wialon was stopped).
When you hover the mouse cursor over the point of the chart, tooltips appear.
