Resource/Account ACL
If a user gets access to a resource, they can view and use its contents (geofences, jobs, notifications, drivers, report templates, and so on) for tracking purposes as well as create such objects in this resource in the main interface of Wialon.
If a resource is also an account, the advanced access rights (such as adding payments, restricting services and determining their cost, and so on) are applied to it. Such operations are possible only in the CMS Manager interface.
Standard rights
The standard (Item ACL) rights which can be applied to resources/accounts are described below.
View item and its basic properties
Allows seeing whether system objects such as units, users, unit groups belong to this account. It is usually written on the first tab of their properties dialog.
View detailed item properties
Applicable to accounts only. The second and third sections of the account properties dialog become visible as well as the Services, Restrictions, and Advanced tabs. If the end user is given this right to their account, the Account tab will appear in the user settings which allows viewing the current balance of the account, information on used and available services, etc.
Delete item
Allows deleting the resource with all its contents. However, to delete an account, you should additionally check the Manage account box.
Query reports or messages
For resources, this check box allows to generate the Log table and see how different users created, edited and deleted the contents of the resource (the Manage item log checkbox is required). It also allows the user to generate reports on drivers and trailers, as well as driver and trailer groups if they belong to this resource. For accounts, this check box gives permission to see the Statistics tab (the history of payments and withdrawals) but only if you check the View detailed item properties box, too. A similar section appears on the Account tab of the user settings.
Edit not mentioned properties
Allows editing the FTP-server settings on the Advanced tab of the account.
Standard access rights (Manage access to this item, Rename item, View custom fields, Edit custom fields, View admin fields, Edit admin fields, Manage item log, View and download files, Upload and delete files) work for resources/accounts as described above.
Such checkboxes as Change icon and Edit ACL propagated items do not affect resources or accounts at all.
Special rights
The table below displays special rights which can be applied to resources/accounts.
| Resource ACL | |
| View geofences | Allows viewing the geofences created within a resource. |
| Create, edit, and delete geofences | Allows editing and delete the geofences of this resource, as well as create new ones. |
| View jobs | Allows viewing jobs created within a resource. |
| Create, edit, and delete jobs | Allows editing and deleting the jobs of this resource, as well as create new ones. |
| View notifications | Allows viewing notifications created within a resource. |
| Create, edit, and delete notifications | Allows editing and delete the notifications of this resource, as well as create new ones. |
| View drivers | Allows viewing drivers and driver groups of a resource. In addition, it allows viewing the automatic binding list of the drivers. |
| Create, edit, and delete drivers | Allows editing and deleting the drivers and driver groups of this resource, as well as create new ones. Moreover, it allows creating and editing the automatic binding list of the drivers. |
| View passengers | Allows viewing passengers created within a resource. In addition, it allows viewing the automatic binding list of the passengers. |
| Create, edit, and delete passengers | Allows editing and deleting the passengers of this resource, as well as create new ones. Additionally, it allows creating and editing the automatic binding list of the passengers. |
| View trailers | Allows viewing trailers and trailer groups created within the resource. Moreover, it allows viewing the automatic binding list of the trailers. |
| Create, edit, and delete trailers | Allows editing and deleting the trailers and trailer groups of this resource, as well as create new ones. In addition, it allows creating and editing the automatic binding list of the trailers. |
| View report templates | Allows viewing report templates created within a resource. |
| Create, edit, and delete report templates | Allows editing and deleting the report templates of this resource, as well as create new ones. |
| Manage account | For accounts only. Combined with the Delete item checkbox, it allows completely deleting the account from the system, together with the resource and its contents, account creator and all objects created by this user. In combination with the View detailed item properties checkbox, it gives permission to control the billing plan and payment (the General tab), number and cost of services (the Services tab), and some other parameters (the Restrictions tab). |
| View orders | Allows viewing orders created within a resource. |
| Create, edit, and delete orders | Allows editing and deleting orders of this resource, as well as create new ones. |
In the main Wialon interface, only manipulations with inner resource contents are possible (i. e. geofences, notifications, report templates, drivers, etc.), including the permission to see the log of content changes. The account-related activities (such as payment control, tariffication, etc.) can be performed only in the CMS Manager interface.
